If you have a 2015+ F150, you might be surprised to know that you can put the plastic upper console off a 2017 raptor into your truck and use it as your up fitter switches. All that is required is the actual upper console and the wiring harness that goes along with it. It comes out to be around $300 for everything but you get to have switches that look like the factory installed them.
Same with the Super Duty upfitter switches in the overhead console. I'm not 100% sure, but I expect they are the same as the ones from the Raptor.
Have you researched this completely? I ask because I know the switches fit, but I'm fairly certain that you also need the relays too. I don't know what they cost.
Here is a thread from the Super Duty forum. Note, you'll want to make sure to get the console that is the right color to match your interior.
You can probably find more detailed info by searching further in the 2017 Super Duty section...but this a good start. https://www.ford-trucks.com/forums/1...light=Upfitter
