cutting out on acceleration
Old Sep 7, 2003 | 11:02 AM
cowgirls f150 4.6's Avatar
cowgirls f150 4.6
My '97 F150 4.6 V8 just desided today that it wanted to cutout on me while my RPMs were up. As long as they don't get above 2,500 it seems to be fine. I was going up hill and it started to do this today then the check engine light came on flashed a few times then went soild. What on earth could make it do this all of the sudden? Could it be an O2 sensor, plugged fuel cleaned, fuel pump? It acts like it's not getting gas then it does then it doesn't again. Could someone help me so I don't have to pay an arm and leg to find out that something just needs to be cleaned? (Cleaned air filter already).
Old Sep 7, 2003 | 01:38 PM
retired2001's Avatar
retired2001
First of all "Welcome" to FTE from Canyon Lake, Texas! Second, go by your local "AutoZone" or parts store and see if they will check for "Error Codes" on your truck's computer. That can save you a lot of "pain" in trouble shooting the problem. You may have hit it with the "fuel filter", but if the "check engine light" came on, it should have set an error code. Good luck!
Old Sep 8, 2003 | 07:38 PM
D Harry's Avatar
D Harry
My 95 4.6 started to cut out, almost like someone was turning it off and back on again, really fast. It was the MAF sensor. Have some pull the codes.
Old Sep 9, 2003 | 02:30 AM
cowgirls f150 4.6
Thanks guys, I took it and had the codes ran. It turned out to be a plugged fuel filter which in turn fouled my plugs so a tune up is all it needed. At least it was nothing major.
manuel transmission
38
Jan 13, 2020 12:24 AM
xjcamaro89
2004 - 2008 F150
19
Dec 20, 2015 06:25 PM
robmnj
1997 - 2003 F150
Dec 28, 2014 08:42 PM
short76
Sep 8, 2009 10:05 PM
fourwheelin
New Member Introductions
Nov 2, 2006 01:38 PM
