428 rebuild kit
Old Sep 7, 2003 | 11:01 AM
390fourby's Avatar
390fourby
428 rebuild kit
What are the best products to buy to rebuild my 428. Has anyone had good or bad experience's with a certain brand? My local parts store sold me a gasket set made by Detroit Gasket, and I think that the look kinda cheap. The rear main cap side seals didn't even have the little steel rods that you push in.
Also, I have a new cam, oil pump, timing chain set and performer 390 intake that I bought for my 390 {but I found It had a cracked block}. This can all be used in my 428 right ? Are there any 390 parts that won't fit on a 428?
Old Sep 7, 2003 | 04:53 PM
gtex's Avatar
gtex
428 rebuild kit
I'll throw in my 2cents:
I use Fel-Pro RACE (remainder to assemble a complete engine) gaskets sets. With the exception of those gaskets specified by Edelbrock for the intake and heads.
I'de reccomend the copper exhaust gaskets with headers or those reccomended by your header manufacturer. My FPA headers came with gaskets.
All of your 390 parts will work on the 428. The blocks pretty much indentical with the exception of the rotating assembly. A 428 crank is externally balanced. You will need to have it balanced or use a 428 flex-plate/flywheel.
hope that helps.
Old Sep 7, 2003 | 06:41 PM
390fourby's Avatar
390fourby
428 rebuild kit
I have the 428 auto tranny flywheel, but the ring gear teeth are wore pretty bad, can I just get a new ring gear and have it welded on my flywheel? Am I supposed to use special gaskets with the Edelbrock intake?
Thanks for the info!
Old Sep 7, 2003 | 07:50 PM
gtex's Avatar
gtex
428 rebuild kit
I figure if you get parts welded to your flywheel, you'll have to get it balanced anyway. I'd just find a good 428 flywheel.
The Ed RPM intake I'm using has instructions to use specific Fel-Pro #1247 gasket. I suspect it's good for yours as well.
gmill09
Ford Truck Parts for Sale
Nov 5, 2013 09:11 AM
Bigjl
Nov 17, 2012 01:53 PM
73 ford guy
29
Feb 12, 2010 08:51 PM
FE 390
13
Sep 26, 2003 08:51 PM
sgreen
Jan 26, 2001 09:58 AM
