New F350 Project
I just picked up a 1984 ford F350 Crew Cab, 4 Speed, 460, with 4x4.
I want to make it a good camper 4x4. I know the front end in not good for offloading as it has so many pieces. I want to get a Solid Axle for the front and upgrade the back if it is worth it. I want to upgrade the Springs durning the change over to a solid axle as well. How do you tell what front end I have? It is not tagged with d50 d40 or whatever it might be. I am not a mechanic and have NO idea what I am doing. the truck has 60,000 miles and it sat for lots of its life. The previous oner bought it from a fire department and put a inline fuel pump in to feed the 460 as the in tank pumps were out. I think he just put a hooked pump up by the engine and it just sucks on the old pumps like an assist pump. I just ordered two new in tank pumps for the motor and I hope it is the right setup. The selector valve works.
The truck when getting hot does not run well or at all. The fuel coming through the inline pump turns to vapor and bogs down the motor or kills it. It sounds like it is starving for fuel. when it cools down for a hour or so or if it is not a hot day this thing can burn roast the big tires.
When she gets gas The 460 runs and sounds great but their is a very slow leak on the oil filter mount and on parts of the upper block. I also need a breather and other missing parts.
On the back of the motor there is two ports (on right and left) with tubes coming off to the top end of the motor. The previous owner taped one of the open tubes ends up with some kind of heat tape. When I peel the tape back I can hear what sounds like exhaust chugging. I think this is part of the AIR/smog system that was disconnected and just blocked off
My main questions:
-What Axle do I look out for for the front end?
-What changes do I have to make to the springs and front end parts to mount the new axle?
-Can I block off the two tubes coming off the block with a tapered plug?
-What oil breather should I buy?
-Where are good instructions for changing out the two pump setup?
-What looks wrong with the motor just from the pictures I posted?
-How do you remove the oil filter mount to replace the two seals?
-How do I fix the leaks I posted pictures of at the top of the block?
-What part should I be greasing or adding oil too under the truck?
-What would you do if this was your project?
-What maintenance hold be done on a setting truck?
Thank you so much for taking the time to read my post!
You want a Dana 60. They were used in F350 4x4s from '85 1/2 through 1997. '91 and older axles will be the king pin type, '92-97 will have ball joints. The king pin axles are stronger and more desirable but harder to find and more expensive.
The springs are completely different so you'll need F350 specific springs for a '85 1/2 or newer solid axle truck. You'll also need the Dana 60 specific lower U bolt bracket for the left side. These can be tough to find; they are no longer produced and I'm not aware of any aftermarket companies who make them. You'll need the track bar and mounting bracket as well. Since the D60 was never offered as an option in '84, you'll have to drill the mounting holes in the engine cross member for the track bar bracket. Don't worry, its easy. One of the holes from the old twin traction beam bracket is in the correct location...use that as a guide and drill the other two.
D60 trucks also used a double cardan front driveshaft to eliminate vibration concerns that also requires a specific yoke on the transfer case. To my knowledge this yoke was only used on the Borg Warner transfer cases so if you have a New Process 208 like I do, it won't fit. My original driveshaft did fit but I never use the four wheel drive so I can't verify any vibration concerns.
One final thing you'll need: All D60 trucks used taller spacer blocks under the rear springs to even out the ride height, so you'll need a set of those as well.
Ideally it would be easiest to find a complete donor truck so you'll have all the parts you need to swap it in, but it is doable if you are able to track down everything separately. I just finished this swap on my own '84 a few months ago and it was well worth it.
What do you think you will be doing off-road with a Camper that required a Dana 60 front end?
I see on Rockauto, parts site that you may have a mechanical fuel pump on the engine and a "low pressure" fuel pump for the tank(s). Is this your current setup? Do you have a mechanical pump on the engine?
If you have an aftermarket air filter housing, then a stock breather won't work. You can get something like this https://www.summitracing.com/parts/spe-4273/overview/ (just input the engine size to be sure to get one that fits your stock valve cover.)
If it were my truck, and for Camper use, I would leave the suspension as is - and focus on making sure the engine/transmission is in good shape. I would add the dual battery setup (if not already there).
I'll look over your photos again and post back if I see anything noteworthy. EDIT - looking over the photos - the main thing that I would do first, is the fuel line routing. It's a real mess.
I found out that the Thermactor (air injection) ports in the cylinder heads for the 460, use a plug (like a mini-freeze out plug) to seal them. It is part number
Napa 2188 or EPC-224-A in Pioneer.
Some 460 forum members said they just fill the opening with "High-Temp" RTV. You could also remove the pipe and cut the ends then crimp them shut, and reinstall the flange.
Good luck with your project.
