Front bumper 73 Highboy
Are the front bumpers different on a highboy vs a standard F250? I was told since the frame is narrower on the highboy the front bumper brackets are at least different, but what about the bumper itself? Anyone know where I can get a set of highboy bumper brackets for 1973? Are the brackets different from year to year on them? I'm not sure whats all different here, but I'd like to get a bumper set to go on my highboy. Thanks!
1967/77 F100/350 (except 1973/77 Ranger XLT w/horizontal bumper pads); 1978 F100/350 (except Ranger XLT/Lariat w/horizontal bumper pads) before serial number AG0,001.
Note: 1964/66 F100/350 bumpers are similar, but the ends are shaped differently, why I said 1967/77 instead of 1964/77.
Narrow frame has nothing to do with front bumpers, because...the frame is only narrow at the rear...behind the cab.
33 1/2" width between the inner frame rails behind the cab: 1961/72 F100/350; 1973/77 F250 4WD (High Boys); 1973/79 F350 Cab & Chassis & Regular Cabs on the 140" wheelbase.
37 1/2" width between the inner frame rails behind the cab: 1973/79 F100/150; 1973/79 F250 2WD; 1973/79 F350 (except as noted above); 1977/79 F250 4WD (not High Boys).
D3TZ-17752-A Right & D3TZ-17753-A Left .. Front Bumper Brackets / Obsolete ~ No Ford dealer or obsolete parts vendor has any.
1973/77 F350; 1973/79 F250 4WD
any consolation my bumper is off a 2 wheel drive 77,that I will be sending to tri city to be dolled up.I didnot have to drill any extra holes to make the two wheel drive bumper fit on the 4x4 truck.,,,my picture is a highboy truck with the highboy frame 1975 F250,,,the bumper fit perfect and then I picked this up on craigslist for next to nothing,even these bumper bars are specific to early years and the later seventies
Weird, because I took the bumper I will use off a 77 F150 two wheel drive sitting here, and it will NOT fit my 73 F250 high boy, without brackets.
We looked at it several times. No holes in the front of the frame rails to mount it on the 73. The 77 F150 mounts on the end of rails.
F250 4WD's and F350's require bumper brackets (see post #10), but F100/150's and F250 2WD's do not.
These bumpers have two mounting holes per side. If optional chrome front bumper guards with rubber pads are installed, the bolts of the guards fit into these holes.
The bolts for the optional push bar (aka brush guard) also fit into these same holes.
1978 F100/350 & Bronco bumpers from serial number AG0,001 and 1979's look different, but either type will fit.
1961/63 front bumpers look similar to C4TZ's, but have three mounting holes per side using a triangular pattern.
