larger tranny pan?
Old Sep 7, 2003 | 10:09 AM
Liquid Metal's Avatar
Liquid Metal
larger tranny pan?
Hello all, I am new to this board and to diesel. I stoped at a local shop to ask about upgrades(gauges,tranny coolers, exhaust). The guy there said I would not need a tranny cooler just the larger tranny pan. It seems like a good idea. more fluid more cooling time. Has anyone done this and does it work???
Old Sep 9, 2003 | 10:35 PM
Fordman4x4's Avatar
Fordman4x4
larger tranny pan?
I just did a tranny service and I looked into that stuff. The extra capacity of those larger pans arn't really gonna buy you much more cooling. For less than half the price I got a big aux cooler. I also installed the Diablo power valve and swapped to Amsoil ATF. My tranny temps dropped at least 50 deg and that's with a lift and 36's! Don't get me wrong,the pan would help, but not that much...
Nelson
Old Sep 10, 2003 | 05:31 AM
Quadzilla's Avatar
Quadzilla
larger tranny pan?
I agree. A better tranny cooler will do you a world of good, much more than a larger pan.
Old Sep 10, 2003 | 08:07 AM
frankoholic78's Avatar
frankoholic78
larger tranny pan?
My temps with stock cooler and a Mag-Hytec trans pan that hols an additional 8 quarts run a consistent 135 degrees and the most Ive ever seen towin my 9000 lb 5th wheel is 165 in slow traffic stop N go crap....works great for me....I also run dino Atf....my truck prefers Mercon V.........L8TR
Old Sep 10, 2003 | 08:32 AM
theologian's Avatar
theologian
larger tranny pan?
Try to avoid the place that told you that - they are lazy, and don't want to do a proper job.
You need cooling with the largest aux cooler you can fit.
Theo
