Requesting expert help!
Old Aug 6, 2017 | 06:20 AM
Fordman96's Avatar
Fordman96
The first time I stopped for fuel I thought it was a little shady but I thought I was running on fumes so I had no choice. Other than that they were all truck stops.
Old Aug 6, 2017 | 09:25 AM
97-psd's Avatar
97-psd
nice. Hopefully the new pump and filters will get it going strong again
Old Aug 6, 2017 | 09:27 AM
97-psd's Avatar
97-psd
that is one of the reasons I swapped from the Walbro pump to the SD pump. You can buy it at most any parts house if it craps out.
Old Aug 6, 2017 | 12:23 PM
Fordman96's Avatar
Fordman96
Well the super duty pump I have won't accommodate the fittings on my lines so I have to go back with the walbro pump instead.
Old Aug 6, 2017 | 02:04 PM
97-psd's Avatar
97-psd
that is definitely a hurdle, especially when you are on the road. I was lucky in the fact that mine died close to home, and I have a good hydraulic shop close by so fittings were easy to come by. Some people need gobs of fuel so the bigger pumps are good, but the biggest injector I will probably ever use is a stage 1.5 so the SD pump works fine for me.
did you get it buttoned up and running again?
Old Aug 6, 2017 | 06:54 PM
Fordman96's Avatar
Fordman96
I made it home and when I went to leave to the parts store it literally died at the end of the road...
The filters are on, but the pumps are awaiting for my order to be confirmed (hopefully tomorrow) so at 3-5 business days... Wednesday or Friday and she should be running. New UVCH should be in tomorrow.
Old Aug 6, 2017 | 07:50 PM
97-psd's Avatar
97-psd
Did you find any burnt pins or are you replacing as a precaution?
Old Aug 6, 2017 | 07:59 PM
Fordman96's Avatar
Fordman96
Replacing as a precaution. It's rather cheap so why not
Old Aug 8, 2017 | 04:59 PM
Fordman96's Avatar
Fordman96
So this is the harness I got from my local auto parts store. This seems like the wrong harness to me. When I look it up online it shows the harness with the valve cover gasket and the clip on the engine harness.
Old Aug 8, 2017 | 06:02 PM
madpogue's Avatar
madpogue
Hard to tell with the plastic covering the connectors, but that appears to be an internal harness, under the valve cover.
Old Aug 8, 2017 | 08:12 PM
Fordman96's Avatar
Fordman96
That's all it is. They called it an "injector harness"
equium
Jun 28, 2011 05:40 PM
SchaefferUSMC
Apr 4, 2010 06:56 PM
96F250tat
Feb 26, 2010 10:14 PM
tralfamadorian
Mar 15, 2009 02:49 PM
wolf189
16
Dec 16, 2001 10:33 PM
