Should i put 35s or 37s on my level 350? i will be keeping the factory 20'' wheel because i like the factory look. Also, what MPG are you guys seeing with bigger tires? thanks
I think EpicCowlick has 37's on his leveled SD. I believe he is using stock wheels as well. If I was savvy enough to post a link to his thread I would, but I can barely type on a keyboard as it is....
I put 37s toyo rt and they do rub at full lock
I havent seen any rubbing on the sway bar
.. as for mpg my truck has 3.55s and its getting 13.0 mpgs but i do drive it a little crazy..
Now for having 37s i dont complain i love the look
Exact same for me. I have seen signs of rubbing on the lower trailing arm at full lock, but no paint wear so far on the sway bar...not to say it isn't rubbing there as well. The rubbing is so minimal that I can easily live with it for the look it gives the truck. It's a giant truck and deserves giant tires!
I have not yet because I have been too busy at work. However, I plan on using Forscan to update it soon, as well as making other changes.
Thanks,
Chris
Hey Chris! When you figure out how to do that with FORSCAN let me know, because I just spent the weekend trying to do just that. I have 37x13.5x20's and could not make it work. Looks like I live with it or go by a speedo calibrator.
