What's this leaking hose on my 2.0L Zetec?
OK, so what does that mean in terms of needing to be fixed? I've seen it suggested that the CCV valve is an integral part of the plastic valve cover, so I need to replace the entire cover rather than a simple $10 valve.
As long as there is not excessive blow-back as to where it will foul the throttle body (and that does happen and the reason for throttle body service).
Check your OWNERS MANUAL for suggested service. An oil separator may help if excessive. In the older days, fresh air was sourced from the air cleaner/box so the oil mist contamination would have less effect on fresh air ingestion.
IreallyLikeFords
01-21-2009 08:49 PM
djmac
01-13-2004 09:15 AM
