Steering Wheel Vibrates When Braking
Old Aug 2, 2017 | 02:26 PM
andym's Avatar
andym
Not necessarily... but the deposits might concern me. I would have to look at them. Honestly if there's any concern just replace them.
Old Aug 2, 2017 | 03:56 PM
pirate4x4_camo's Avatar
pirate4x4_camo
FTE Remembers
Rotors "warp" with age as they go through heating and cooling cycles, the warpage can be measured with a dial caliper and is called lateral runout. ford spec is a max runout of .0015 of an inch,
Brake pads often wear In a pattern and can be measured and deciphered by a good tech so corrections can be made.
Since you are having the work done you are the mercy of the shop but for my money I would go with high quality set of new rotors and pads as I recall you bought this off a used car lot ? Used car lots are notorious for using the cheapest brake parts available since all they are after is to pass a safety check and be able to say "new brakes"
If your steering wheel is oscillating during braking your wheel bearings ( unit bearing ) tie rods and steering box should also be inspected.
Old Aug 2, 2017 | 04:01 PM
Country_Mouse's Avatar
Country_Mouse
Thanks, we bought used from a Ford dealership. They machined rotors and new brakes prior to purchase.
What pads and rotors do most of you use for towing with Ex?
Old Aug 2, 2017 | 04:04 PM
Country_Mouse
Steering wheel doesn't oscillate just vibrates but checking steering components will be done regardless. They did say needs new damper.
Old Aug 2, 2017 | 04:23 PM
pirate4x4_camo
FTE Remembers
If you are sticking with the Ford dealer then go with motorcraft. Otherwise Hawk LTS pads and powerstop rotors are a popular setup.
Also, almost guaranteed motorcraft parts were not used when the ford dealer reconditioned it for resale, that cuts too deep into their profit margin.
Old Aug 2, 2017 | 04:35 PM
Country_Mouse
Read somewhere that Ford OEM and Motorcraft are not the same. True? Dealer said would use OEM. It would cost $100 more than at shop that uses Akebono. Worth it?
Old Aug 2, 2017 | 04:41 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I doubt it.
Old Aug 2, 2017 | 04:52 PM
pirate4x4_camo
FTE Remembers
Motorcraft is Fords parts sales company, they sell parts that meet their specifications and are branded with motorcraft. It is probable that Akebono supplied the brake pads ford installed at the factory as well as currently supplies to motorcraft. The main thing the motorcraft name means to you is that the part meets ford specs, who supplies ford the part is not that important to you since ford is the company who is standing behind it.
Old Aug 2, 2017 | 04:54 PM
Country_Mouse
Kinda like Costco.
Old Aug 2, 2017 | 04:58 PM
Country_Mouse
Right ones?
Hawk Performance HB302Y.700 LTS Brake Pad
Amazon Amazon
Could someone link me the rotors for 2001 6.8 4x4? Many choices just googling powerstop rotors.
Worth calling shop to see if they can order different parts than the Akebono? Seriously, the more I ask the deeper I get into this.
Old Aug 2, 2017 | 05:05 PM
pirate4x4_camo
FTE Remembers
Kinda like Costco.
Exactly, And suppliers change over time.
Fwiw, Motorcraft rotors have a 24 month warranty, I'd start by taking it back to the dealer you bought it from and pursue that, they will have the invoice on file if they did the safety inspection/ work for resale.
Thought:
If your Ex had new brakes when you bought it and needs brake work @ 13k of towing I would look at your trailer brake setup and make sure it is functioning correctly.
Old Aug 2, 2017 | 05:10 PM
Country_Mouse
Thought:
Good idea but they didn't replace rotors when we bought it, just machined them. Brakes still have 7mm but trying to get to bottom of pulsation..sigh..
We have the Prodigy P3.
Old Aug 2, 2017 | 05:15 PM
  #28
pirate4x4_camo
FTE Remembers
Right ones?
Hawk Performance HB302Y.700 LTS Brake Pad https://www.amazon.com/dp/B000IERZRY..._HGKGzbMMJG3ZK
Correct,
Akebono makes quality American made parts and is a OEM supplier and at this point I think developing the relationship with your shop is more important then you telling them what parts you want based on some forum advise.
However, since you asked.....
Summit is a great supplier, free delivery, I can order at 5pm and have them the next day in NorCal
I often order from summit via eBay just because it is easy.
Power Stop Brake Rotor AR-8580XPR | eBay
Old Aug 2, 2017 | 05:19 PM
  #29
Country_Mouse
Correct,
Hey I really appreciate that! This shop has good reviews and he goes to our church so I'd love to call him our new mechanic. Installing bumpstops for $15 where ford wanted $140. Installing steering stabilizer for $145 where Ford wanted $300. Rotors and pads not as deep of discount but $100 less.
Old Aug 2, 2017 | 05:36 PM
  #30
Country_Mouse
As long as no one is telling me to run for the hills with that brand, lol!
