Sponsored by: Real Truck
Proper diagnostics
Old Jul 31, 2017 | 08:04 AM
Mike1's Avatar
Mike1
Proper diagnostics
Ok so my automotive knowledge is mostly in 1995 and older drivetrains, but my 03 F350 5.4L which sits the majority of the time was called to duty on Saturday to go pick up it's new bed. The engine is running rough, lack of power, feels like it's missing a cylinder. Hooked the scanner to it because no CEL is on,
My codes are P0303 and P0171 so misfire on #3 and Lean on bank one.
I popped the hood, removed air filter, a little dirty but passable, I sprayed the MAF with MAF cleaner.
I climbed on top, checked #3 COP and it's wiggling, I have not removed it, I really don't know what to expect when I do, but I do know that none of the other COPs are loose, so can I expect a bad Boot? Is it shot, am I probably looking at a busted spark plug?
Other than fixing #3 cyl problem, what other diagnostic steps should I take to fix these codes? I bought the truck 1.5 years ago, at 132K it now has 135K, I haven't done anything to the engine except an oil change and fixing the leaking trans cooler lines and power steering lines. All other work has been on the front diff and front driveshaft. and some light electrical. I have no maintenance history on it other than what I have done to it.
Thanks for any advice
Old Jul 31, 2017 | 08:35 AM
alloro's Avatar
alloro
None, fix the misfire and see if it takes care of both codes before you do anything else.
Old Jul 31, 2017 | 09:50 AM
Mike1's Avatar
Mike1
So the possible misfire on #3 could also cause the lean on bank 1 code? I would have thought the opposite, just because if it's not firing that raw fuel would be dumping into exhaust causing a too rich condition.
Old Jul 31, 2017 | 11:45 AM
projectSHO89's Avatar
projectSHO89
"Lean" codes to not mean the engine is running lean, they actually means the opposite. The fuel table have shifted to their maximum positive enrichment limit but the O2 sensors are still reporting the extra rich exhaust as "still too lean". Usually caused by too much un-metered air entering the system, other causes are indeed possible. A misfire dumps unburned fuel into the exhaust and can compound the issues.
Fix the misfire, reset the system and re-test. You may have multiple issues.
Old Jul 31, 2017 | 03:50 PM
Sam I Am's Avatar
Sam I Am
So is the hold down bolt not on the COP?
That could be the whole problem right there.
Old Jul 31, 2017 | 04:05 PM
Mike1's Avatar
Mike1
that's what i thought also but i felt and its there so i sprayed pb blaster on all the cop bolts and ordered a couple of new ones from ford....they ain't cheap either...lol
Old Aug 2, 2017 | 08:32 PM
Mike1's Avatar
Mike1
New coil on #3 fixed it BUT...the po must have been in there before? The bolt is good but the hole os stripped.
dclack
Jun 20, 2022 09:38 AM
SteevenH
1997 - 2003 F150
Jun 3, 2013 10:01 AM
randy217
Jan 3, 2013 07:28 AM
fredo181
Modular V10 (6.8l)
Sep 15, 2009 10:08 AM
bad69boss
Mar 25, 2007 10:52 PM
