No power
Old Jul 29, 2017 | 07:45 PM
kboomisme's Avatar
kboomisme
No power
I just bought a 95 F350 7.3, and it has less power than the last 3 I have had with the same motor. It has 133k miles. Automatic. It smokes when it is started for the first time of the day until warmed up, and smells like unburnt fuel. It has an exhaust leak, I am assuming up behind the turbo somewhere, because the smoke comes from there when first started as well. I also have a fuel leak under the fuel pump somewhere as well. I have been told that there is a "weep hole" on the pump that is common to leak.??? The truck is bone stock. So with all this said, can anyone point me in the right direction??? Thanks in advance.
Old Jul 29, 2017 | 09:51 PM
97-psd's Avatar
97-psd
First, fix the leaks you have already identified. Loss of boost and loss of fuel will hurt performance.
Old Jul 29, 2017 | 10:00 PM
farmert's Avatar
farmert
Have you changed the fuel filter? If not try changing it, and while the filter is out carefully clean the screen in the return, in the filter housing. It is about 1 1/2" down from the top of the housing. You can use a Q-tip with the cotton removed to scrape the screen. The smoke on first start up sounds like 1 or2 bad glow plugs. Replace with Motorcraft ZD11 glow plugs only, as others don't seem to last, and some will swell in the head when they go bad resulting with a head removal to get it out. The smoke from behind the turbo is probably the donuts on the up pipes need replacing, or better yet replace the up pipes with a bellowed set from Clay at Riffraff diesel, that does away with the donuts.
Old Jul 30, 2017 | 03:56 PM
knottyrope's Avatar
knottyrope
Low fuel pressure is what I went through and mine leaked also.
Once that was done and finding my EBPV closing it's been running well.
Next up is injector clearance. That retards timing if too close and rough running when cold.
Old Jul 30, 2017 | 05:16 PM
kboomisme's Avatar
kboomisme
Thank you for all of the replies. This gives me some ideas to try. What do you think about the "weephole" being the cause of my fuel leak? Also, knottyrope, I don't know what a EBPV is. I am pretty new to the diesel worls, as far as doing my own repairs. Thanks again.
Old Jul 30, 2017 | 09:37 PM
hdgapeach's Avatar
hdgapeach
EBPV: exhaust back pressure valve.
I'd be getting my fingers in the valley between the heads, feeling around to see exactly what is wet underneath. There's a lot of stuff in that valley that carries fuel (fuel bowl, fuel pump, fuel lines). Any of them, or more than one, could be a source for fuel leaks.
Get you a flashlight and go diggin'!
fivo2fst4u
Jul 11, 2015 06:13 PM
guisepi
26
Dec 15, 2013 12:27 AM
5fords&Counting
Dec 6, 2012 09:01 AM
banjopicker66
Mar 19, 2010 07:52 PM
kent's f-350
15
Oct 15, 2008 11:47 PM
