HELP!! Really Stuck Distributor
Old Sep 6, 2003 | 07:57 PM
grif95's Avatar
grif95
Unhappy HELP!! Really Stuck Distributor
Please help?!?!?!?!?
I just purchased a 1978 Ford F-150 4x4 with a 351M. The timing needed setting so I went to adjust the distributor. She wouldn't move. I have tried soaking it in PB Blaster, heating around the distributor, you name it. The top has broken off and all I have left is the shaft. What can I do to get this thing out.????!!!??
Please help.....very frustrated.....
Thanks,
grif95
Old Sep 6, 2003 | 08:32 PM
GT40man's Avatar
GT40man
thus is common, try a lot of stuff. usually a hammer and grunt will work the best.
some has used different solvents and lubracants.
Old Sep 6, 2003 | 08:50 PM
Torque1st's Avatar
Torque1st
Posting Legend
There are a number of threads here on this problem, for fast info check out the search function.
Old Sep 7, 2003 | 05:59 PM
cwethy's Avatar
cwethy
I just went thru the same thing. Busted off the top and everything. Dont know what finally got it loose but after tapping very gently (LOL) on it with a hammer and prying on it with a crowbar it finally came out. I did the PB blast and heat and that did not seem to help.
The only thing different was that I took off the radiator hose and so the distibutor soaked in antifreeze overnight and then it came out. I don't know if that is what did it or why. Maybe a combination of everything.
Old Sep 7, 2003 | 09:34 PM
grif95's Avatar
grif95
Thank you all very much for your replies.
Thankfully, I had the day off today to fool with the thing for more than a few minutes.
A crow bar, PB Blaster, a torch, a drill, some more PB Blaster, and a shanknut wrench. It turned freely and I was able to pull it out with my hand. By the time I was through, I had 3 pieces to the distributor, but it was out.
What really let the PB blaster work was I drilled out a hole in the base of the distributor flange so that the lubricant could get past the dried up o-ring.
Thanks again guys,
grif95
