Driveline angle TSB
Old Sep 10, 2017 | 08:25 AM
zephyr74's Avatar
zephyr74
I will check for vibration this week and call the dealer.
Old Sep 10, 2017 | 08:50 AM
KULTULZ's Avatar
KULTULZ
Question
Wondering...
Do all of these trucks being described have OEM towing packages and if so, is the vibration w or w/o towing?
Old Sep 10, 2017 | 11:14 AM
System's Avatar
System
Prolocutor
It happens on mine empty and towing exacerbates it.
Old Sep 10, 2017 | 11:38 AM
ncl's Avatar
ncl
I ordered on 8-15 it said a job#2 truck. Is this issue on earlier builds or all of them? I guess Ford can pay a driveline shop to fix mine if they cant. Fingers crossed
Old Sep 10, 2017 | 05:23 PM
KULTULZ's Avatar
KULTULZ
Post
See if this applies- Truck hops on concrete highway - Ford Powerstroke Diesel Forum
If not, another possibility-
Old Sep 10, 2017 | 09:51 PM
HRTKD's Avatar
HRTKD
Originally Posted by Karl4Cat
Just wondering if you guys with the issue could clarify a little about the vibration. My truck is going in for a few warranty issues this week and I also have a highway vibration that is worse when towing. When into the pedal up a long grade towing my RV, I get an out of round vibration. It cycles evenly every couple seconds. Two seconds of smooth as glass, two seconds of a slight whole truck vibration. Anyone else with something similar? I'm fairly certain the dealer will say they can't replicate the issue but I will mention the TSB if it relates. No one has a link to the TSB by the way?
I thought I had posted yesterday in one of the threads that my F-350 was smooth. I jinxed myself. I have pretty much the same symptoms that you do Rodney. I was towing light today. It was just my side-by-side. I started feeling that vibration, then it would go away, then it would come back. I was on fairly new asphalt so I'm pretty sure it wasn't the road. I'm seeing some vibration in the steering wheel but it may be possible to see the vibration anywhere in the truck. I'm familiar with the feel of warped rotors and this isn't it.
I'm going to be towing heavy this wednesday. If the problem is worse with the heavier trailer then I'm definitely going to be showing this to the dealer. A vibration like I'm feeling can't be good for the suspension, specifically the shocks.
Old Sep 11, 2017 | 07:02 AM
System's Avatar
System
Prolocutor
Let me know what you find Jim. My truck goes to the dealer tomorrow. I'm certain they won't be able to replicate the issue and will brush me off.
Old Sep 11, 2017 | 08:56 AM
Biggsy90's Avatar
Biggsy90
Mine does exactly what you were talking about. Typical sine wave type vibration. Not sure why it does it. Definitely feels like a driveshaft vibe to me. Interested to hear what they have to say. Mine is most pronounced at around 75. And pavement really has to be smooth to feel it. If it's rough, can't tell if it's happening or not.
Old Sep 11, 2017 | 09:02 AM
System's Avatar
System
Prolocutor
Good to know I'm not alone. The more that people report these things, the quicker Ford knows it's not an isolated issue and works on a solution.
Old Sep 11, 2017 | 09:07 AM
HRTKD's Avatar
HRTKD
I'm going to hold off installing my new shocks until I get the vibration resolved. The new shocks may mask the vibration enough that the dealer's technician may blow me off.
Old Sep 11, 2017 | 09:48 AM
System's Avatar
System
Prolocutor
My FOX 2.0's have no effect on it Jim so I'm doubting your new shocks will make a difference either.
Old Sep 11, 2017 | 09:55 AM
HRTKD's Avatar
HRTKD
The other reason to hold off on the shock install (besides the fact that the Florida vendor sent me the wrong one and they are shut down this week) is that I don't want to put undue wear on the shocks. I'm wondering if the vibration is why there is oil leaking out of the OEM shock (besides the fact that the OEM shocks suck).
Old Sep 11, 2017 | 10:43 AM
  #28
afacey's Avatar
afacey
I have noticed the same, although I was thinking it was my 295's. are you guys running stock wheel/height trucks?
Old Sep 11, 2017 | 10:50 AM
  #29
HRTKD's Avatar
HRTKD
My suspension/drivetrain is completely stock.
Old Sep 11, 2017 | 11:17 AM
  #30
Biggsy90's Avatar
Biggsy90
Stock as well. I tried the stock 20" rims and 18"rims from a 2010 that I used on my old truck and had no vibe.
