Battery/Alternator Issues
I saw how close it was an just filed off some dressed the threads so the nut would come off & no ok an reinstalled the Alternator.
I also had to do it on a alternator, I got from a box store..
The main thing is you don't want it to shorting out on the engine block right.
So cut the lug shorter and be done with it.
Orich
Orich
Ok, thanks for saying so. I'll review the clearance issue. Making the lugs shorter is pretty straightforward.
BTW, the main mounting bolt was tight on my alternator... I always check that again after I apply tension to the fan belts.
In addition to making those lugs shorter, what's the possibility of adding some insulation? It seems like I ought to be able to glue a rubber or plastic mat on the block to insulate that area. Heat would obviously degrade it over time.
Any guess about how much of a gap is needed to keep those lugs from arcing over to the engine?
0.045 inch (ie. "spark plug") gap should be able to withstand several thousand volts before arcing over... won't be getting that much out of the alternator. I think Orich's right, the mounts on the alternator would have to be loose for those lugs to get that close to the engine.
In my younger days, I was once privileged to witness a 200,000 volt corona. The test equipment failed on Friday evening, arced over and the very air ionized, causing a conductive path that didn't stop until they shut down the power supply on Monday morning.
I've also seen the million-volt Tesla coil in operation at Fry's, in Fremont, CA.:
Makes my alternator seem kinda puny.
I've also seen the million-volt Tesla coil in operation at Fry's, in Fremont, CA.: https://www.youtube.com/watch?v=Ij2HPfJ05nM
Amperage (conductance) is the power moving along.
Voltage is the "push" that moves the power.
Seeing your video makes me curious how many volts is in an average lightning bolt.
Geophysical conditions matter; what happens in the High Sierras probably takes a lot less volts than what happens during a lightening storm out on the Great Plains.
I've been caught in a lightening storm in the High Sierras. It's enough to scare the Atheism out of a person!
I g**gled it out of curiosity.
According to the National Severe Storm Laboratory, a single lightning bolt can have 100 million to 1 billion volts, and it contains billions of watts, depending on whether it is positive lightning or negative lightning. Lightning strikes ground in the United States approximately 25 million times each year.
Positive lightning, which comprises less than 5 percent of all lightning, originates on top of the clouds, rather than the lower portion of the storm, as negative lightning. These type of lightning can travel up to 25 miles horizontally in the air before they strike the ground and are sometimes called "bolts from the blue." Because of the greater distance to the ground, they develop much higher voltages.
Parts and Accessories Catalog
Section 145
page P-8244
Engine Wiring System (8 Cylinder 360, 390 engine)
1968/72 F100/350
In the upper left corner, where the Alternator is shown, it looks like there are some insulating caps designated "10A375".
Would that help stop shorting from the field terminal to the engine block?
Any idea what the full part number is and if they are still available?
Section 145
page P-8244
1968/72 F100/350
