Sponsored by: Real Truck
Possible Sensor problem?
Old Sep 6, 2003 | 06:23 PM
99fatboy's Avatar
99fatboy
Just recently my truck will not start on the first crank and may take 3-4 before it will turn over. It will crank but it will not idle high enough and just die and after a couple tries it will start and I'm ready to go and it acts fine. It's very inconsistent and doesn't happen too often but it's annoying. Had a few people tell me it's probably a sensor. TPS or something or other. Anyone had an issue similar to this and can help with some advice? No othe known issues at all. I have changed the fuel filter recently but this problem didn't happen directly after.
99 DRW 6.8L gas
Old Sep 6, 2003 | 07:26 PM
99f350sd's Avatar
99f350sd
Idle air control valve dirty or bad.At least pull it and clean with carb cleaner.. Could be tps but I doubt it.
To test put your foot on the accel and give it a little.... while cranking that will simulate the IAC being open...Give just a crack.
The IAC controls all the idle the throttle plate is basically closed on fuel inj vehicles.
Old Sep 7, 2003 | 11:22 AM
99fatboy's Avatar
99fatboy
Thanks for the advice. I'm looking for the IAC now. Is it attached to the throttle body? I do see some type of module attached to the throttle body with a plug and 2 screws holding it on. Can't find anything else? If it is it, it will be a pain in the *** to loosen those two screws to get that module out.
Old Sep 7, 2003 | 11:58 AM
99f350sd's Avatar
99f350sd
There's the throttle pos sensor not that. an aluminum looking thing. I think it has two screwws also..You are in the right area.
Old Sep 7, 2003 | 12:03 PM
99fatboy's Avatar
99fatboy
yes the aluminum looking thing with the 2 vaccum lines and plug attached to it. I'm on it now. I'll let you know what happens.
thanks.
Old Sep 7, 2003 | 09:40 PM
V10man's Avatar
V10man
There is one large (5/8" maybe) hose on the IAC. It comes from the intake snorkle. The IAC is located on the passenger side towards the back of the engine. It's a PIA to get to, at least for me it was. There are 2 bolts holding it on. They face the firewall. There is a pic of it on this site somewhere.
