Ignition problems
Old Jul 26, 2017 | 11:33 AM
Tom Langford's Avatar
Tom Langford
Ignition problems
I have a 67 f100 I have rebuilt and I can not get the truck to stay running it's like the run portion of the tumbler is not working do you think the tumbler is bad it's the original tumbler
Old Jul 26, 2017 | 11:46 AM
KULTULZ's Avatar
KULTULZ
Post
You mean IGN SW cylinder or the switch itself?
Run a jumper wire from the B on the solenoid to the + on the coil and see if it runs.
TeachNlive4ever's Avatar
TeachNlive4ever
Auto parts stores sell new iggy switches...
Old Jul 26, 2017 | 11:48 AM
Tom Langford
I'll try that now
Old Jul 27, 2017 | 08:27 AM
orich's Avatar
orich
If your truck has the round terminals pins changes our it's the ign. key switch/plug
The switch with the round pins over heated an would loose contact an not start.
The real problem was the plug so the plug & switch need to be changed out to a flat blade type switch as noted below.
Orich
Hope this helps
Round pin faileds
Old Jul 27, 2017 | 10:39 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
None of this info affects the OP's truck, since it's a 1967.
OP has a 1967 that uses a one year only ignition switch: C7UZ-11572-A / Motorcraft SW-583
The POS switch that would short out and catch fire (C8AZ-112572-A) was used on all 1968/69 FoMoCo vehicles (except Bronco), 1970 F100/750 & Econoline before serial number G90,001.
This POS switch was replaced in 1971 with D1AZ-11572-C / Motorcraft SW-1054
dustyroad
47
Jun 26, 2020 11:37 AM
corkel
Electrical Systems/Wiring
Aug 1, 2014 02:19 PM
hatemakings/n
Jun 18, 2005 08:34 PM
bigblockford460
Mar 14, 2005 09:27 PM
jellisproductions
Feb 2, 2004 03:10 AM
