First 7.3
Old Jul 25, 2017 | 09:36 PM
FORD-or-Die's Avatar
FORD-or-Die
First 7.3
Bottom line inherited a 95 7.3 4x4(all the time?) 4inch lift with 33's and diablo chip 50k on new tranny 210k of motor body, will never get rid of this truck to many memorys. So basically im young without alot of money and need to know the best maintenence schedule whats expected to fail etc. Been sitting 1-2 years drained both tanks new filter motor oil filter air filter checked fuel bowl and cleaned, also the hpop reservoir was empty(guess from sitting so long?) Filled it up cranked immedietly, and useing "power service diesel kleen" for additive is that good if not better. I will be useing this as a work truck not a toy i need it to act like one.
Old Jul 25, 2017 | 09:40 PM
z31freakify's Avatar
z31freakify
Change all fluids, check for exhaust leaks (up pipe to collector and boost leaks. Do the down pipe and get rid of the stock air box, and do the 6637 MOD or if you want $$$ get an AFE air intake system.
Old Jul 26, 2017 | 10:01 AM
madpogue's Avatar
madpogue
What model? Automatic or manual transmission?
Old Jul 26, 2017 | 11:54 AM
FORD-or-Die
automatic, I would presume the e40d. but not 100% positive
and what would be the safest way to test for air leaks with exhaust and boost?
Old Jul 26, 2017 | 12:08 PM
knottyrope's Avatar
knottyrope
leaf blower on exhaust and a squirt bottle of soap
compressor and a fernco coupling for boost
make sure you have 45 PSI min on fuel WOT in third
Old Jul 26, 2017 | 12:30 PM
FORD-or-Die
WOT in third? what does that mean
Old Jul 26, 2017 | 12:49 PM
knottyrope's Avatar
knottyrope
Wide Open Throttle in third gear
Old Jul 27, 2017 | 10:23 AM
FORD-or-Die
what kindof fuel additive would yall suggest?
Old Jul 27, 2017 | 11:27 AM
paintubturner's Avatar
paintubturner
I used Hot Shot Secret in my truck. I bought the Diesel Duo package. It was 80 bucks
Tanelson9210
26
Apr 13, 2019 09:51 PM
Chance Whitlock
Aug 12, 2017 07:05 AM
Crewcab Turbo
May 10, 2011 08:48 PM
Edfromgeorgia
Nov 25, 2009 02:52 PM
Kwikkordead
Oct 13, 2007 01:27 AM
