Coolant Question
Old Jul 25, 2017 | 08:36 PM
'02 Excursion Guy's Avatar
'02 Excursion Guy
Coolant Question
I have a '02 Excursion, 7.3L PSD with 238,000 miles. I have to constantly add water to the coolant reservoir but no leaks what so ever and no oil contamination. Any ideas why I am losing coolant and where it is going???
Old Jul 25, 2017 | 08:50 PM
metru's Avatar
metru
did you check the rear heater core in the rear right fender it may be leaking there or from one of the hoses under the right hand floor
Old Jul 25, 2017 | 09:07 PM
'02 Excursion Guy
No I didn't but I will check it out. I don't have any leaks, wouldn't it be leaking from those areas? I don't have any wet carpet and I'm constantly going in and out of the storage compartment where the jack is located and I don't have any leaks there???
Old Jul 25, 2017 | 09:17 PM
metru's Avatar
metru
from what i saw you probably wouldnt notice in some cases if it was collecting in the plastic housing best when to know if the front or rear heater cores are leaking an the cause of your lost coolant is if you turn on the heat an it has a sugary sweet smell to it. its how i usualy find if a vehicles heater core has gone bad an is leaking within the housing without ripping the thing apart
Da_Lariat_Chariot
Mar 28, 2015 02:22 PM
Wayne242
Modular V8 (4.6L, 5.4L)
Aug 10, 2013 06:32 AM
zgiannijonesz
1997 - 2003 F150
Oct 30, 2007 08:43 PM
Saxon
Dec 12, 2005 08:47 PM
Neckfitter
Oct 11, 2000 11:44 AM
