Trouble With Holley
Old Jul 25, 2017 | 08:15 AM
Hennington400's Avatar
Hennington400
Trouble With Holley
Hey guys I have a major issue. I recently bought a 670 cfm street avenger Holley carb. Now I took the carb all the way apart, cleaned every port and blew the whole thing out. I know its clean. I install the carb and the engine comes alive, its very stout and snappy but it will not idle. I have a 750 cfm 4160 I am running. its too much for my application but it idles. I cant for the life of me figure whats going on with the street avenger.. Any suggestions would be perfect!!!! Thanks
Old Jul 26, 2017 | 02:23 AM
KULTULZ's Avatar
KULTULZ
Post
Vacuum leaks?
Do you have a vacuum gauge?
Old Jul 27, 2017 | 10:34 PM
3rd-coast-thumper's Avatar
3rd-coast-thumper
What motor is it on? What size jets are in the carb?
Old Jul 31, 2017 | 11:37 PM
baddad457's Avatar
baddad457
Jet size has nothing to do with the idle circuit.
Old Jul 31, 2017 | 11:41 PM
baddad457's Avatar
baddad457
If The 750 was a double pumper only then would it be "too much" carb when you nailed the gas pedal at a dead stop. When you bolted the carb on, did you reset the initial timing first, before tuning the carb ? What is the timing set at ? This has everything to do with the idle settings. What ignition are you running on this motor ?
andrew's64
Apr 27, 2016 03:15 AM
rustywheel68
Apr 18, 2013 08:45 PM
Dance-Trax
17
Jan 24, 2010 12:26 PM
Dirt Head
Mar 15, 2006 11:05 PM
Rat wagon
Mar 22, 2003 02:24 PM
