1978 - 1996 Big Bronco
302 rebuild
Old Sep 6, 2003 | 02:54 PM
srm148's Avatar
srm148
302 rebuild
I have a 1980 ford bronco that has had the motor replaced prior to me buying it. all I know is that is it supposed to be a 305HO. how do I find out what year the motor is? I need to know this before I start getting parts to rebuild it. any ideas where the numbers on the block are, and if I have to remove the motor to find out? thanks.
Old Sep 6, 2003 | 03:30 PM
DW2455's Avatar
DW2455
302 rebuild
305HO? not! on most all v8 ford blocks the casting number is on the side of the block just above the starter but its inverted, other than useing a mirror if the motor is still in the vehicle and its not hot, then stick your hand down there PALM up faceing the block, slide your fingure under the embosment, feel the digits, try to feel the first two digits, now squeez the digits with you fingur for a few seconds then pull your hand out and read the numbers that are now embosed in you fingur. DW
Old Sep 6, 2003 | 03:36 PM
stepman's Avatar
stepman
302 rebuild
Wow, good tip. Never thought of something like.
Old Sep 6, 2003 | 03:49 PM
srm148's Avatar
srm148
302 rebuild
sorry!!!!!!! brain fart. I meant a 302 HO. cant believe I said that!! thanks for the tip.
