Adding an Inverter?
Adding an Inverter?
Looking for brand recommendations for adding an automatic pure sine wave inverter.
I have not decided if I want to only set up a few outlets yet or all of them. I'm thinking price will determine what I eventually end up doing because I'm planning on adding solar also.
If anyone has found so good write ups on this subject and wouldn't mind sharing them I would appreciate it. I'm trying to learn as much as I can before buying anything.
As always thanks in advance.
No clue on the pure Sine Wave. I installed a cheapie Schumacher 2000w modified Sine Wave recently. The kids are watching TV and we have phones charging. I have run a small vacuum cleaner. A tire Inflator compressor. Ceiling fan. Air conditioner fan only not ac.
I just plugged in my 30 amp main cord to the inventor and turned off the circuit breaker for the stock 12v converter. Not the best way but it was simple and works for what I need. I also have a 1000w I am going to hook up to see if it is more efficient.
I was looking at pure Sine Wave first and decided to give this a try. Please post pictures of your install when complete as I am not thrilled with mine yet.
Thanks for the replies.
After doing some more research I really leaning towards setting up a system with an automatic transfer switch and tying the converter into my sub panel. Reasons being, 1, I don't want it forgotten that the inverter is in service and the generator get started and cause an issue. 2, I will be the one have to go out side in the middle of the night flipping the switches.
Chuck, from what I have read, your wife's electric blanket will not work unless you use a pure sine wave inverter.
funny.. blanket will not work.. but a Smart TV and a satellite receiver will...
Enjoy your New project...
I worked on on some pretty scary do-it-yourself projects, so be careful! I also have solar on the roof.
Steve
Griz
All the major players have similar models that do the same things. Average lifespan according to the manufacturers is 9-10 years. However, most can be remaned when they go down. Normally they have to be sent to an authorized repair center. They will not simply sell you the parts.
Repair costs last time I sent one in was under $300 and turn around time was very fast, less than one week.
Here is a link to an industry standard http://www.xantrex.com/documents/Inv...-01_rev-2).pdf. The wiring diagrams are at the end. I would suggest if the diagram does not make sense to you, do not attempt the install yourself.
And yes they are pricey.
Steve
Steve
Steve
Steve
looks like it installs between the shore power cord and the rv fuse panel if I read option #1 correctly?
