Sponsored by: Real Truck
Front Stub Shafts
Old Jul 22, 2017 | 01:17 PM
five20too's Avatar
five20too
Front Stub Shafts
Quick question here. I'm getting ready to take apart my front end because I'm sure one of my spindle bearings is trashed. Never done this before but it can't be that difficult. My question is about the shaft itself. Guzzle's write up states that if the shaft is damaged in any way that it must be replaced. I would like to know what the negatives would be to replacing the bearings and running it like it is, if in fact it is damaged. Like I said, I haven't even verified if mine are worn or not. I'm just trying to figure this out beforehand. If the vehicle will drive now and just makes a crappy noise because of the bearing then why couldn't it work ok with a new bearing?
Old Jul 22, 2017 | 02:14 PM
DogRidesInBack's Avatar
DogRidesInBack
The shaft may no longer properly fit in the inner race. At minimum, you'll simply trash out another bearing.
Old Jul 23, 2017 | 03:12 PM
jetjockey99's Avatar
jetjockey99
the needle bearing in the front hub/bearing assembly rides directly on the stub shaft. If the locking hubs are locked there would be no problem but in 2wd and unlocked hubs the bad stub shaft would most likely eat the needle bearing in short order.
Old Jul 23, 2017 | 03:52 PM
five20too's Avatar
five20too
Ok thank you all for your replies. I guess I will tear it down and see how bad it is
Old Jul 24, 2017 | 02:16 PM
brian42's Avatar
brian42
Veteran: Navy
There's no minimum requirement so it's going to be based on your comfort level.
IMO it depends on how bad the damage is to the machined surface where the needle bearing rides. I would be more critical of the passenger's side since it has a long main shaft so that one bears more weight than the driver's side hub.
Here are some write-ups I used to tear mine down:
https://www.ford-trucks.com/forums/3...ll-joints.html
2004 F250 Ball Joint Replacement
Ford Super Duty Ball Joint Replacement Procedure - Superdutypsd.com
They are for ball joints so you can stop when you get as far as you want to go on the teardown.
superstroked6.0
Apr 26, 2017 11:49 AM
wanabe2
Jan 2, 2013 09:33 PM
n20
20
Sep 13, 2010 05:12 PM
schlepprock250
Dec 29, 2008 03:49 PM
rssnape
Dec 22, 2003 07:46 AM
