Truck axle loading, predicting sag
#31
How much fuel was in the truck? That could potentially account for the 145 lbs difference. Based on my research, the payload rating includes a full tank of fuel, so at ~7lbs per gallon x 34 gallons = 238, if you weren't full, that could account for some of the difference.
I'm trying to run my own calculations and follow your math to get down to per axle curb weight. How were you accounting for the weight of you, your wife, the B&W hitch in the back, and the F1 tonneau cover? You mentioned you backed out those weights to get to 8025 - could you explain your calculations for that?
In terms of my predicting my scaled weight (prior to rolling onto the scale), that's a bit more complicated.
(1) I took the base axle loads from the 2017 Ford fleet specs: F/R 4479/3020
(2) I calculated the weight of my optional equipment as the difference between my trucks weight (GVWR [11500] - payload sticker [3332] = 8168#) and the base weight of an unoptioned truck (add F/R from step 1 to get 7499). Optional equipment weight = 669 pounds.
(3) I assumed 60% of options landed on front axle and 40% on rear. Giving me a F/R weight of 4880/3288.
(4) Since I was at 3/4 tank of fuel, I accounted for this by subtracting 63.75 lbs allocated 33% front and 66% rear. F/R 4859/3245.
(5) I added the people in the front (380) allocated 58% front 42% rear. F/R 5080/3406.
(6) I added the hitch (267) and the tonneau (72) 100% to the back axle. The tonneau was closed (CG roughly centered over axle) and the hitch CG is basically over the rear axle. F/R 5080/3745.
I hope that all makes sense.
Travelchief
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
09-22-2017 12:09 PM
frdcowboy
06-21-2004 01:59 PM
lmskater
04-12-2003 08:25 PM
GeneStoner
10-12-2002 09:00 PM
