Iac questions
Old Jul 21, 2017 | 12:54 PM
96beigef150's Avatar
96beigef150
Iac questions
Ok I have a few questions. I've been having a idling loss of power issue in my truck. Decided to do a few tips to see if that helped, only got as far as the iac. Took it off to clean it with intake cleaner and now truck won't start unless starting fluid is used and then it's just like before. Before it would idle just kinda erratic from minute to minute. One minute itll sound like nothing's wrong and next it'll literally struggle to idle to the point the engine shakes the truck. Before I removed the truck would start with no issues and after I removed it and cleaned it it'll just crank to no end unless starter fluid is used to jump it. So my main question is the adjuster screw in the side should move that internal gear right cause I have it off truck ATM and it just turns both ways and does nothing. 96 f150 OBD2 4.9l mazda 5 speed
Old Jul 21, 2017 | 04:27 PM
Conanski's Avatar
Conanski
Yeah... that screw on the side of the throttle body is not an idle speed screw it's a throttle plate stop screw that is just meant to prevent the blades becoming jambed in the bores. So do your best to put everything back the way it was and move on.. this isn't where your problem is.
I suggest you check fuel pressure and if you haven't done so already pull codes and post up the results for those things.
evan_nugget
17
Dec 19, 2017 07:22 PM
06cumminsman
Apr 5, 2016 06:54 AM
suicidecharley
1978 - 1996 Big Bronco
May 16, 2015 08:17 PM
caleballen95
1997 - 2003 F150
Dec 30, 2012 11:37 AM
Adrenaline4X4
Feb 28, 2010 04:35 PM
