What is the best spray on bedline in a are sol can? I want to do my truck tool box and other parts that the paint is chipping and peeling. I have Rhino liner in the bed and it has worked great but can't find it in a spray can.
Bought a kit on ebay once. I was very happy with the results. Prep work takes a little time, but for a first timer is looked like I'd sent the truck out to have it professionally done.
Interesting - I started this quest yesterday myself. This stuff seems much more durable than your basic undercoating and like you have little areas that I want to protect with something a bit more durable than your basic undercoating. Like the round thing on the drivers side of the tailgate that allows the tailgate to open & close. Since the tailgate side moves over the side that's fastened to the truck, if I did both with undercoating it would just scrape off. There are a few other places that I would like to hit as well. I did a search yesterday, most of the ones I found required a compressor, spray gun and come in cans. Here are some that don't:
I have a plastic bed liner on my 86 F250. I hope to get a spray in bed liner soon. Here is a good thread on spray in vs. roll on bed liners. I'm on the fence. If I don't go with Raptor then I will get it professionally done.
Like Chuck said, you will need an air compressor. The Raptor kit has everything else you'll need for the liner. I used my 20 gallon Lowe's air compressor and it did the job.
I scuffed up the entire inside of the box, wiped the dust out with paint thinner on a rag and let the box dry. Did some masking and sprayed.
