Tpms ?
Old Jul 19, 2017 | 08:52 PM
Flooringit's Avatar
Flooringit
Tpms ?
I ordered a new set of rims and tires. Stock ones will be for towing and 295s for tooling around town. I am gonna order a set of sensors so I don't have to break tires down and swap them. Are they all the same. I've looked online only see ones for up to 2016 not 17. Are they the same? Will I have to reprogram each time I swap them out.
Old Jul 19, 2017 | 09:05 PM
KWDAILYD's Avatar
KWDAILYD
Following. I don't have the same issue as you but was wondering if the truck has to go to Ford every time the tires are rotated to have the TPMS reset when the tires are in a different location.
Old Jul 20, 2017 | 06:59 AM
crewzer's Avatar
crewzer
Lightbulb
You can reset the TPMS at home (or wherever) when you rotate the tires; you don't need to go to the dealer. The procedure is reasonably well described in the OM (v3, pages 398-400 for SRW trucks). Here's a summary version of the procedure:
1) Rotate tires.
2) Drive truck >20 mph for >two minutes (this activates the TP sensors).
3) Follow instructions to reduce individual tire pressure in sequence by location (LF, RF, RR, LR; each pressure change tells the system which sensor is where).
4) Adjust each tire to target air pressure.
HTH,
Jim / crewzer
Old Jul 20, 2017 | 07:13 AM
crewzer's Avatar
crewzer
Lightbulb
As long as the new wheel and tire set's sensors are compatible with Ford's TPMS, I would expect that swapping one wheel & tire set for another would use the same TPMS reset procedure as that for rotating tires (see above).
HTH,
Jim / crewzer
Old Jul 20, 2017 | 08:02 AM
KWDAILYD's Avatar
KWDAILYD
1) Rotate tires.
HTH,
Jim / crewzer
Thanks for the response. I will look at the manual today. I did this when I changed pressure in the rear tires and it worked. On another site guys were saying it had to be reprogrammed at the dealer or tire store when rotated. This makes more sense to me.
Old Jul 20, 2017 | 08:20 AM
crewzer's Avatar
crewzer
Unhappy
... On another site guys were saying it had to be reprogrammed at the dealer or tire store when rotated...
That's unfortunate.
To some degree, I can understand people not reading the OM, which can often be wrong, incomplete, and/or poorly written. Besides, who would want to read through hundreds of warnings about how something in your wonderful new truck could injure or kill you?
I find that downloading the searchable OM pdf to be the most useful way to (quickly) find (hopefully useful) info.
Best of luck!
Jim / crewzer
Old Jul 20, 2017 | 08:28 AM
RugbyRef's Avatar
RugbyRef
Following this as well! Just ordered new wheels and tires with TPMS installed (not using factory TPMS). Hopefully, the process above works. Thanks SD!
Old Jul 20, 2017 | 08:55 AM
HRTKD's Avatar
HRTKD
Do yourself a favor. Go to Discount Tire and ask about the EZ Program TPMS sensors. They can program them to mimic your existing sensors. That way, when you swap from one set of tires/wheels to the other, there is absolutely nothing to do. The truck has no idea you switched.
Old Jul 20, 2017 | 02:02 PM
Flooringit's Avatar
Flooringit
I read where the aftermarket tpms sensors weren't very reliable. So I didn't want to keep going in and getting tires broke down to fix them. Where I bought the tires would've put sensors in for 150$ but there are online for 65$ everywhere. And those are oem. What is the reliability of the discount ones ?
Old Jul 20, 2017 | 02:17 PM
HRTKD's Avatar
HRTKD
I haven't had any issues (after they were programmed) in the past year.
The sensor I got is smaller than what my OEM sensors were, so I suspect that might make the wheel easier to balance.
Old Jul 20, 2017 | 03:43 PM
afacey's Avatar
afacey
discount ones are $60/ea -- how much are OEM?
Old Jul 20, 2017 | 03:56 PM
Flooringit's Avatar
Flooringit
60$ For all 4
Old Jul 20, 2017 | 03:58 PM
afacey's Avatar
afacey
60$ For all 4
Do you have a part number and location to buy from?
Old Jul 20, 2017 | 04:18 PM
Flooringit's Avatar
Flooringit
Amazon Amazon
I actually bought mine on eBay 55$. Some people don't trust eBay. I've bought lots of stuff only thing so far fake was a pair of nikes.
Old Jul 20, 2017 | 08:30 PM
HRTKD's Avatar
HRTKD
Only if you don't negotiate. I think I got mine for ~$35 each.
