Increaseing towing cap.
Old Sep 10, 2003 | 04:55 AM
NSANT's Avatar
NSANT
It's an E4OD.I guess I'll have to wait and hope the lobster season this year is really good and maybe get a different truck this spring.
Old Sep 10, 2003 | 08:04 AM
jbalestri's Avatar
jbalestri
I'll have to check my owners manual and see what my 90 is rated at just for giggles and grins.
Old Sep 11, 2003 | 10:26 PM
dtpatt2's Avatar
dtpatt2
How much are you wanting to tow?
Old Sep 12, 2003 | 04:59 AM
NSANT's Avatar
NSANT
My camper is about 8000# dry.
Old Sep 12, 2003 | 01:12 PM
jimandmandy's Avatar
jimandmandy
HD is a smog emissions term and has nothing to do with towing capacity. Anything with a GVWR above 8501lbs is "heavy duty" according to the EPA. Your problem is that the truck is too heavy for the engine. There is not that much left of the CGWR for the trailer. It is not a safety issue as far as tires, bakes, frame, etc. because they are independent of engine size.
If that chip really adds 27ft-lb and if it is at a low rpm (probably not), then it should let you tow a little more trailer weight. By all means get the biggest trans cooler you can find for that E4OD!
What are your terrain conditions? Sea level, level ground, or high altitude and steep grades? How slow can you stand to go? What kind of distances do you plan to tow? Use some common sense judgement.
Jim
