Hello everyone.
Old Jul 16, 2017 | 11:42 AM
Leadfootfarm's Avatar
Leadfootfarm
Hello everyone.
I just wanted to say hello to everyone here. I just picked up my first "antique" Ford and I will be (and already have been) picking through all of the posts here looking for information. I am not 100% certain of what I bought as the guy who had it didn't know, it didn't come with a title, has an older license plate that is no longer in the system, and I have yet to find a VIN or serial number of any sort. (Mind you, I just brought it home yesterday and haven't spent any time taking it apart to locate the one on the bell housing.)
So, any information any of you may be able to provide based on these pictures would be great. What I do know, or at least think I know, is that it is a 46 or 47, 1.5 ton, stake side bed with PTO driven dump, manual transmission connected to an inline 6, and it used to have a brush guard on the front.
Old Jul 16, 2017 | 12:17 PM
Rust Wrangler's Avatar
Rust Wrangler
Welcome! Nice find, it looks to be in decent shape and unmolested. Best way to tell what you have is the serial number at the top of driver side frame rail near the cross member. She's a beauty!
Old Jul 16, 2017 | 02:49 PM
38 coupe's Avatar
38 coupe
Welcome to FTE. You have made a great start, you have pictures in your first post. As stated above your serial number will be stamped into the top of the frame on the drivers side between the fire wall and the radiator, typically it is found near the steering box. It was hand stamped at the factory and may be faint. Steel wool or similar can be helpful on a rusty frame, as can chalk.
Again, welcome.
Old Jul 16, 2017 | 05:17 PM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
I see you are in WA from your profile info, which I had suspected seeing the pics of your truck being "protected" by the wild blackberries. It looks to be a fine one. Add my welcome. Stu
Old Jul 16, 2017 | 11:26 PM
GB SISSON's Avatar
GB SISSON
And another welcome from a fellow Western Washingtonian. Seems I have seen your truck on CL, but not sure. It just looks familiar. Great find and keep us posted with progress reports and photos!
Old Jul 17, 2017 | 10:49 AM
Leadfootfarm
Originally Posted by GB SISSON
...Seems I have seen your truck on CL, but not sure. It just looks familiar...
I am sure that you did. I found it on CL and it was located in south Seattle. It had been sitting where it was for 10+ years and the guy had to cut back the blackberry bushes just to take pics. It is a complete truck minus the radiator and battery which some scrapers decided to steal. The truck definitely needs some work but I got it for a song because the guy needed it moved immediately and was out of options.
A question for you guys that I can't seem to find a direct answer to... are all of the truck cabs the same on these trucks, whether 1/2, 3/4, "tonner", or 1.5 ton?
Old Jul 17, 2017 | 11:48 AM
Rust Wrangler
"A question for you guys that I can't seem to find a direct answer to... are all of the truck cabs the same on these trucks, wether 1/2, 3/4, "tonner", or 1.5 ton?"
Yes, the cabs are the same. The front fenders on the big trucks have a larger opening to accommodate the larger tires. There are a few interior details that are different between them as well, like steering wheels and speedometer.
Old Jul 18, 2017 | 06:38 PM
willowbilly3's Avatar
willowbilly3
Looks like a nice straight cab. Nice find and welcome
Old Jul 18, 2017 | 09:36 PM
Leadfootfarm
OK. I found a VIN. From what I gather it is *1GT235448*. I dont know if the "1" might be an "I" or not because I am not familiar with the VINs from back.
If you guys could check out the pic and let me know what you think. Also, where can I find a VIN decoder for this truck?
Also, it has a 158" wheelbase.
Thanks!
Old Jul 18, 2017 | 10:25 PM
FireEngineMike's Avatar
FireEngineMike
VanPeltSales.com has the decoder.
Old Jul 18, 2017 | 10:30 PM
Leadfootfarm
I tried there and it is not coming up. It show "1GAxxxxxx" but not "1GTxxxxxx".
Old Jul 18, 2017 | 10:50 PM
FireEngineMike
Stu will probably post the info in the next day or so.
RestoreYourFord.com under "Technical Info": GT through the 1940s indicates a 6-cyl, 1-1/2 ton, 134" wheelbase truck. It is a 1947 if the first number is a 7, not a 1.
The 158" wheelbase has a G8T designation. I'm sure you did not make a 24" mistake so it is time for this rookie to say "Wait for Stu".
Old Jul 18, 2017 | 11:16 PM
46fordtruck's Avatar
46fordtruck
1G is a G series 6 cylinder
T is heavy duty truck (doesn't indicate wheelbase)
The rest is the serial numbers.
That's all the info that can be had from the number. Based on the serial numbers, your truck is a '46.
Old Jul 18, 2017 | 11:18 PM
Leadfootfarm
I appreciate the info.
How might I find out exactly what year the truck is? Would the numbers on the bell housing give me more info?
Old Jul 18, 2017 | 11:21 PM
46fordtruck
No, the numbers on the bell should, if it's the original trans, match the number on the frame. The last 6 digits fit in the range for '46 6 cylinders.
