41-lean
Old Jul 18, 2017 | 07:54 PM
Zacbkennedy's Avatar
Zacbkennedy
i built an egr block off plate to stop that vaccum leak. i was reading and heard it was bad to pull the plug wires off of the motor when it was running? i also replaced the pcv grommet and valve. because smoke was leaking out of that as well during the smoke test. and the missfire is still there. i also reset codes41, 31, and 75 still come up
Old Jul 18, 2017 | 08:57 PM
Lead Head's Avatar
Lead Head
Nothing wrong with pulling plug wires with it running.
Old Jul 19, 2017 | 07:21 AM
Zacbkennedy
yesteday after installing the egr block off plate and pcv valve and grommet i also poured in a can of bg 44k and on the way to work today i didnt notice a misfire not once. ill know in a couple days tonight ill also pull plugs and see if i can find that misfiring cylinder
Old Jul 19, 2017 | 01:29 PM
Zacbkennedy
TOday at lunch I tried pulling spark plug to find the misfire. They all affected the engine. So I smoked it again there's no vaccum leaks. So I moved to fuel pressure. At idle with the regulator hooked up pressure is 31 unplugged it's at 41. Could that be the problem? It has a rebuilt fuel pump and new filter
Old Jul 19, 2017 | 02:41 PM
Lead Head's Avatar
Lead Head
That behavior is normal for the fuel pressure.
Old Jul 19, 2017 | 02:46 PM
'89F2urd's Avatar
'89F2urd
In order to confirm that fuel pressure is not the cause of your lean condition, you need to test the fuel pressure under load to ensure it will maintain that 40+ psi while accelerating.
Old Jul 19, 2017 | 05:40 PM
Zacbkennedy
i drove home with the regulator unplugged and vacuum line capped. surprisingly it felt like it drove better didn't seem to misfire even when i tried to force it. i have a decent drive tomorrow ill try it again. ill have to buy a fuel pressure gauge now seeing that today was the last day at my job.
Old Jul 19, 2017 | 05:48 PM
Zacbkennedy
just read codes again, still the same. when the computer is running its test and raises the rpm. its very smooth and then you can kinda hear the miss especially in the exhaust
Old Jul 19, 2017 | 11:27 PM
Lead Head's Avatar
Lead Head
If it runs better when the vacuum line unplugged, then it sounds like you really do have a lean condition.
Old Jul 20, 2017 | 12:06 AM
vjsimone's Avatar
vjsimone
31 – (EVAP control system below minimum voltage) Check & clean the connector to the purge valve.
75 -Identify & mark any wires or connectors on your 1990 wiring harness that are not connected.
Old Jul 20, 2017 | 07:18 AM
Zacbkennedy
How do I fix the lean condition? This has really got me stumped
Old Jul 20, 2017 | 07:33 AM
GoinBoarding's Avatar
GoinBoarding
I would start with checking fuel pressure under load. I route the fuel pressure gauge between the hood and cowl, then set it on the windshield so I can read it while driving. See what the pressure does when accelerating. The other info that would be helpful is the oxygen sensor voltages but I don't know how to get those with EEC-IV systems.
Old Jul 20, 2017 | 09:07 AM
  #28
vjsimone's Avatar
vjsimone
The lean indication could be because you are actually running lean & fuel pressure does need to be verified.
A lean indication can be due to a low or lack of O2 signal to the computer from one of the sensors.
If the heater is not working in the O2, a low or lack of O2 signal to the computer can occur.
Power to the O2 heaters can be measured.
A signal from the O2 sensors can be measured.
The common ground wire for the Heater & the O2 Signal in each Sensor are very important and can be verified.
Typically, when the computer receives a lean indication it compensates by adding additional fuel delivery to the engine.
If the O2 sensors are not working properly, and the computer is compensating by adding additional fuel delivery the engine will run rich all the time.
Are the O2 sensors New?
Old Jul 20, 2017 | 11:08 AM
  #29
'89F2urd's Avatar
'89F2urd
PLEASE check fuel pressure under load, like I've been saying over and over....without confirming that, it's absolutely pointless to continue.
Old Jul 20, 2017 | 02:49 PM
  #30
Zacbkennedy
The o2 s sensors are new. I'll buy a fuel pressure gauge in the morning and mount it as you say. Do I need to drive it with the fuel regulator hooked up for the test? The fuel regulator is still unplugged and no misfire yet. It also overheated on me today I'm wondering if that's coming from the engine running lean? I also don't have an overflow and will be adding one in the morning when I get the fuel pressure gauge as well.
