Tow/Haul Mode Question
At what point do you Guys/Gals decide to use the Tow/Haul mode feature? I asked this question on a Nitro Bass Boat Facebook page and got all kinds of answers. 99% of the time I will not use it because my 2011 F250 SD doesn't even realize the 18' bass boat is back there. The other 1% of the time I use it is when I'm coming down grades and utilize the 'exhaust brake'. I use the Tow/Haul mode when towing my 30' Weekend Warrior but not the bass boat. What are all of your opinions on this? Thanks.
Received 6,845 Likes
on
I tow a 8,000lbs travel trailer on fairly regular basis and am often in hills and mountains. So for me pretty much out of the driveway I am in tow mode. I do not think it makes a big impact on my MPG on flat terrain due to later shifting, but it's very handy on the up and downs.
I've gone east a few times now, and once I get to Iowa, I usually forget the truck has the tow button.
I saw somewhere that a ford engineer had commented on the topic and basically said use it if you want to or don't use it if you don't want to. The truck is designed to work with no problems either way whether empty or towing at the max weight.
Also, here's a snippet from ford towing guide:
The only time I use the tow haul feature is when towing our 14K pound toyhauler. I also use the engine brake for better braking...the way some of the idiot driver's that like to pull out in front of you when towing every extra bit helps. For daily use or when towing my utility trailer I just leave it in drive.
I use it all the time when towing my 21' enclosed trailer - I actually wish it would come on automatically when there is a trailer attached - this antique brain simply cannot remember to hit the switch until after I'm 1/2 down a hill scratching my head as to why the engine brake isn't working. Thankfully my passenger has a way better memory than me and she usually reminds me.
on
