226 Rebuild Advice
#31
Just plastigage'd the main bearings and here are my results:
B1 (flywheel side)
B4 (Crank pulley side)
B1: 0.015"
B2: 0.04"
B3: 0.03"
B4: 0.04"
Everything looks clean but might have lost a page of my shop manual to oil spillage. Are these within or out of tolerance? If it matters this was rebuilt to specs shown in above picture.
Alex
B1 (flywheel side)
B1: 0.015"
B2: 0.04"
B3: 0.03"
B4: 0.04"
Alex
#32
Most definitely left out a zero, lack of sleep is getting to me!
B1 (flywheel side)
B1: 0.0015"
B2: 0.004"
B3: 0.003"
B4: 0.004"
I'd bet B1 is somewhere between 0.0015" and 0.002".
#33
That's much better. I still think B1 is too tight, but if you think it's .002+ then it's ok. Gotta give that oil a place to stratify.
#34
Thanks Mixer! I'll remeasure #1 tomorrow. Want to calibrate this torque wrench first.
As she sits now after 7 hours of wire wheeling. I was covered head to toe in what used to be .75" thick sludge. May not look clean but 4 coats of degreaser and one tortured angle grinder later the majority is bare metal.
Yes I know the valve cover is on upside down. I just threw them on the keep debris from filling the valve chamber.
#37
How would you best deal with this? I was wire wheeling and noticed I kept digging out orange putty, realized it was pure rust paste pouring out. Spent an hour with the screwdriver digging out as much rust gunk as I could before sealing that freeze plug and filling the block with Evaporust. When I get my cooling system built I'm going to run it on Evaporust for the first week to clean all of this out.
Having difficulty getting this plug out though. Any suggestions?
#38
#40
#41
#42
5 coats of engine cleaner with a wash and wire wheel in between each one.
Probably should have waited until it was just a litttttle cleaner but I decided to pull the trigger instead. 3 coats of ceramic Ford Red. I'll be going over some of the components in black tomorrow and replacing some of the parts, hence my lack of taping off.
#45
and down from the deck, thru the water jacket holes. A sharpened piece of 1/8 steel rod works well. The rear bottom is where a lot of crap collects.
