My first time ever paint job (thread)
#63
I kid you not, I worked with an old man that had the softest hand for being a career diesel mechanic. He would literally rub ATF on his hands at the end of the day, every day, then wash them with Dawn dish soap. Always clean and always soft, even in the winter. Crazy, I know, but it worked.
#64
#66
#67
#71
I covered as much as possible with the Chassis Saver while I could, including brake and fuel lines.
I tried to sand blast the inside of the bed, but the pos blaster from HF that I borrowed from a friend didn't work for crap. So I got busy with my DA sander and a wire wheel on my angle grinder. Then used the rest of my Rust Mort to wipe down the entire bed. Used the rest of my primer in the back of the bed.
I then used the Rustoleum Bed Liner for the inside bed.
After that dried over night and into the middle of the next day, I tidied up around the frame and installed the clamp nuts for the new bed bolts (Dorman 924-311). I did have to grind down the frame a little on the two holes 3 down from the front, just forward of the aft gas tank.
Grabbed a couple neighbors to help place the bed back down on the truck and bolted it down. FROM THE TOP!!! But, I got to the last bolt and the dang threads gulled up when I was literally 1/8th of and inch to the bottom. It's always the last bolt that gives me crap. But I don't care, bed is installed. And now the search is on for a replacement bumper, until then, the old rusty bent bumper will do.
I will write up all my lessons learned later when I have time and post more pics. I still got to do little odds and ends, but my truck is back to driving condition and I couldn't be more relieved.
