Oil Drain Mess
Old Jul 12, 2017 | 10:45 AM
pchelp's Avatar
pchelp
Oil Drain Mess
Someone please tell me there is a better way to drain the oil on my 390 instead of letting run all over the engine crossmember ?!
Old Jul 12, 2017 | 11:25 AM
HIO Silver's Avatar
HIO Silver
On newer trucks where the engine compartments are packed tightly, there is a plastic "drainway" to divert the oil to a drain pan.
Fast and easy options:
1. Use a piece of plastic or cardboard formed as a channel so it stays off the crossmember.
2. Order a "Fumoto Valve" and the adapter fitting/tube: Fumoto® USA | Quick and Easy Engine Oil Drain Valves
Old Jul 12, 2017 | 11:26 AM
Tomahawk's Avatar
Tomahawk
Put aluminum foil over the crossmember and into your bucket/pan.
Old Jul 12, 2017 | 11:30 AM
pchelp's Avatar
pchelp
Makes me want to hunt down the Engineer that designed the oil pan !
Old Jul 12, 2017 | 12:18 PM
yellow truck's Avatar
yellow truck
I put a Fumoto valve on mine - saves the 50 year old oil pan and plug from stripping.
Get the valve with the nipple on it so you can put a hose over it and direct the oil into an old jug. Keeps it nice and clean.
Old Jul 12, 2017 | 12:28 PM
pchelp's Avatar
pchelp
Get the valve with the nipple on in so you can put a hose over it and direct the oil into an old jug. Keeps it nice and clean.
yellow truck wins the gold star today This is exactly what i need !!
Old Jul 12, 2017 | 03:47 PM
TeachNlive4ever's Avatar
TeachNlive4ever
If I every get my daddy do's done, I'm going to weld an extra quart patch to my pan to stop that from happening.
Old Jul 12, 2017 | 10:54 PM
HIO Silver's Avatar
HIO Silver
Thanks for nuthin'.
Old Jul 12, 2017 | 11:37 PM
yellow truck
Originally Posted by HIO Silver
Thanks for nuthin'.
I haven't been on before now, but I was going to point out that HIO Silver got there first.
Old Jul 13, 2017 | 07:02 AM
TeachNlive4ever
Yeah, but he didn't post pictures....
Old Jul 13, 2017 | 07:25 AM
ultraranger's Avatar
ultraranger
HIO gets the Rodney Dangerfield award.
Old Jul 13, 2017 | 08:19 AM
pchelp's Avatar
pchelp
Thanks for nuthin'.
LOL, HIO I got as far as "use a piece of plastic" and just moved on to the next comment . No offense meant ⭐️ Here you go. LOL
In all honesty you have truly been helpful on many occasions and I greatly appreciate your responses
Old Jul 13, 2017 | 09:50 AM
yellow truck
Neither did I! All I did was add the point of protecting the oil pan thread. Mine is a 4WD and the original pans are like gold.
Old Jul 13, 2017 | 08:20 PM
GUYDON's Avatar
GUYDON
I cut a gallon plastic jug to the shape I wanted, it worked like a charm... I think I will go with the valve next time though.
Old Jul 18, 2017 | 02:11 PM
CrossPlainCrazy's Avatar
CrossPlainCrazy
Does anyone have a picture of the Fumoto Valve installed and how much clearance it has? That's a very tight space so I am wondering if it has enough room to put a hose on the end?
