The Official Happy Hour Thread - Pull Up A Chair, Sit A Spell, What's The Latest?
Third hobby besides the X and the camper....the boat. Volvo put a fuel pump on that was painted inside for a period of time. It's a combination lift and high pressure pump. The lift pump fills the bowl, the high pressure supplies the injectors. They have little screens in the ends of the pumps that get tiny paint chips lodged in there. Downside is they aren't serviceable (or so the mechanic told me). You get to buy the whole thing to the tune of ~$1200 when they "go bad". I decided to take it apart and clean it. This is the second round in 3 years and may have to be a seasonal thing. At least it's easy to get to and take off the motor.
Well, if you have a 4x4 Ex, that's about to change when you grease the non-serviceable hubs by greasing them through the ABS hole!
Although I do have a question regarding the inside of that fuel pump. Why don't you remove all the paint so the chips are no longer a problem?
Stewart
Stewart
I am spending the day with 3 guitar amps. All dual 6V6 tube amps with 2 or 3 tube preamps. One has a 15" Emeinence Legend speaker in a combo configuration, and the other 2 are heads going through a 12 inch Eminence Tonkerlite. What I am doing today is deciding on which amp to keep. I am swapping brands of tubes to see what sounds best in each amp and then decide which amp will work best for me. It is possible that I may keep the 15 combo ans one of the 2 heads.
Here are the contestants
Fender Excelsior w/pro speaker
Ibanez TS-15H
Egnater Tweaker 15
Yesterday morning I had some fun. I have this old Sencore Mighty MiteII tube tester, so I ran all my tubes(spares too) thru and had a blast. When I was a teenager, I had a tube tester and fixed tractor radios for farmers. It mostly consisted of replacing tubes and blowing all the dirt out and cleaning the pots. Frequently, they would come in with the wrong tubes as farmers figured if it fit the socket it must be the right tube! So they would grab tubes out of old clock radios and try to fix it themselves. I had a blast those few summers.
so how's that for "what is the latest"?
Ibanez TS-15H
Egnater Tweaker 15
Injectors? Heck mine has the electric pump and a Holley double pumper.
What engine do you have? My 4.3L Volvo Penta actually had a prior life as a truck engine from a 2007-2014 Silverado or van.
Stewart
Stewart
Mine's a 4.3L Volvo as well (GXi-D)...it's for sure a good little motor that Chevy Vortec. Some days I wish I had a carb. I've spent the last two nights chasing electrical "issues" that hopefully will turn out to be a bad ground. TPS low voltage and Coolant temp sensor low temperature = engine alarm and limp mode
I'm totally up for suggestions of things to try though! Hot tank it maybe?
Stewart
#28
I hate to assume, but I kind of figured that was the case.
Not being familiar with the pump, I assume (here we go, LOL) there are seals and O-rings that wouldn't allow something caustic to be used to soak the interior of the pump with, to remove the paint, yes?
Stewart
Stewart
#29
Without Fuel Injection the 4.3L is easy to work on. I agree, it is a tough engine. When I bought mine the PO used RTV on the riser gaskets and carb gasket resulting in one blown head gasket and one bent valve plus milkshake oil. I fixed that, overhauled the carb, and many other things it ran great but had an oil leak. I had to drop the oil pan, replace the gasket, timing cover gasket, front seal and add a balancer sleeve. The drain plug has a small drip still but that can wait till my next end of season oil change. I now run with 40-60 oil PSI, 160 degrees and 14 volts from the charging system. All is good! Labor of love.
Fortunately the engine parts can be bought at Advance and Amazon has the marine parts (starter, gaskets etc.)
