Help finding racetrack moulding
Old Jul 8, 2017 | 03:41 PM
Rudytown's Avatar
Rudytown
I am needing to buy full set of moulding top is the wider set with rubber insert, and bottom/back is racetrack for my 77 f150. I can buy some of the parts from Dennis Carpenter but not all. I'm worried about buying what I can from DC and not being able to match quality from another supplier. Does anyone have any other recommendations of worthwhile suppliers?
Old Jul 8, 2017 | 03:51 PM
kegger66's Avatar
kegger66
LMC has a full set for your truck. JBG may have all pieces as well.
Old Jul 9, 2017 | 05:34 AM
rob8210's Avatar
rob8210
I have both upper door pieces that I have no use for.
Old Jul 9, 2017 | 10:49 AM
beartracks's Avatar
beartracks
I thought D.C. had the full set. They area always my first choice. I have a full set used for cheap but I'm in ABQ,NM
Old Jul 9, 2017 | 02:59 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Rudytown
I am needing to buy full set of mouldings, top is the wider set with black vinyl insert. Bottom/back is race track for my 77 F150.
Is your '77 F150 a Regular or Super Cab?
1973/76 Ranger XLT upper fender, upper door and upper cab corner mouldings with black vinyl insert same as 1977/79 Ranger XLT & 1978/79 Lariat with Race Track Mouldings.
The upper quarter panel (bedside) mouldings are different.
The quarter panel Race Track mouldings have a curved end where the vertical Race Track mouldings attach that connect the upper Race Track Mouldings to the lower Race Track Mouldings.
Carpenter, AFAIK, has reproduced all the Race Track Mouldings except for F350 bed mouldings on the 140" wheelbase, Crew Cab rear door mouldings, Super Cab mouldings that extend from the door to the end of the cab.
And possibly the lower quarter panel mouldings that extend from the tool compartment (if so equipped) to the vertical mouldings.
Several years ago, someone was looking for one of these mouldings for an 8' bed. I found one NOS at a dealer in KS: 35 bucks, a roaring bargain!
Old Jul 11, 2017 | 02:20 AM
gijazbo's Avatar
gijazbo
Double post
Old Jul 12, 2017 | 01:26 PM
Johns01's Avatar
Johns01
google the lmc catalog
they make both versions of the trim new using ford's old tooling
Old Jul 12, 2017 | 02:18 PM
bryanmartin's Avatar
bryanmartin
Where are you located? I have a full set ill not using, but shipping them would be a pain.
Old Jul 12, 2017 | 03:23 PM
bulldogcountry1's Avatar
bulldogcountry1
I've got a set.
My truck came with the full racetrack molding. About 15 years ago, I removed the lower molding and found the right pieces to have only the upper wide.
I plan on swapping that out soon for the narrow upper molding, if I can find a set. I can't find anywhere that reproduces it.
Old Jul 12, 2017 | 03:35 PM
beartracks's Avatar
beartracks
If you don't want used do Dennis Carpenter. Everyone else resells their original tooling.
Old Jul 13, 2017 | 11:31 AM
NumberDummy
1973/79 F100/350 Stylesides: Narrow upper bodyside anodized aluminum mouldings: Standard equipment for Rangers (not XLT's!), optional for Customs.
No one reproduces these narrow upper bodyside mouldings. Some of these mouldings are available NOS (R/L cab corners for one example), otherwise you'll have to get used mouldings.
Nodrama
Ford Truck Parts for Sale
Aug 16, 2017 07:15 PM
52runner
Aug 17, 2012 03:18 PM
buckshot1822
Aug 5, 2010 09:40 PM
falcontrucker
Mar 18, 2009 09:36 AM
dmiller28
Dec 15, 2004 09:44 PM
