General Automotive Discussion
For us SBF owners...
Old Jul 7, 2017 | 10:20 AM
Deez-67's Avatar
Deez-67
... it might be time to hit the sperm or blood bank.
Giant American Made Hemi Heads for Your Small-Block Ford!
Giant American Made Hemi Heads for Your Small-Block Ford! - Hot Rod Network
Bolts on to any 289/302/351w and 351c engine blocks
Accepts any existing Windsor style intake manifold
Comes with 2.200”/1.650” Competition Series Stainless Steel valves
Sets up to 2.050” Installed Height (will accommodate big lift cams)
Has 62cc combustion chamber
Uses a Jesel 1.7 ratio shaft mounted rocker system
Has a Yates C3 exhaust bolt pattern (remote chance of existing C3 headers working)
Has accessory bolt holes for use with factory Ford accessories
Uses FelPro 1262R intake gaskets or similar
Uses FelPro 1433 header gaskets or similar
Comes with cast aluminum “Hemi style” valve covers
Uses Flatout valve cover gaskets
Has .700” thick deck for power adder applications
Has raised intake ports for more direct flow to the valve
Flow numbers are 392/intake and 275/exhaust as cast
Will require distributor extension
Comes with lifter valley cover
Uses standard ¾” reach, gasket style spark plugs
Overall width of 9.5 deck engine is 27.5", 8.2 deck is 26"
DieselCamper
17
Mar 3, 2017 06:46 PM
Spktyr
Dec 16, 2016 10:18 PM
dlocklear11
Jul 7, 2010 06:31 PM
mezapu
Jan 26, 2010 05:50 PM
68FE390
17
Nov 3, 2007 03:09 AM
