engine numbers
Old Jul 7, 2017 | 02:13 AM
PIGGYONAHOG's Avatar
PIGGYONAHOG
engine numbers
Good Morning All,., I have found a plate on my motor and need to figure out what motor it is year and model. The numbers are on a plate it says ,"Manufactured for General Motors In USA"
Part number 19210003
Serial number 5542671s/c 763-
NPK1522E3
I am in the uk so any uk links would be very helpfull..Thanks
Old Jul 7, 2017 | 12:15 PM
petemcl's Avatar
petemcl
I'm not sure that you are in the right forum? What is the year, make and model of your truck? What kind of engine is it (I-6, V-8, 4 cyl, diesel, gas)? Also we need pictures.
Old Jul 7, 2017 | 02:14 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I googled that part number and it came back as a GM steering rack. Is the plate just mounted to a bolt on the engine? Pete'd right, we need to know what brand and model engine you have. All engines for the last 40 years have a serial number stamped on the block itself, on V8's it's usually on whichever bank is further forward on the block deck surface.
Old Jul 8, 2017 | 01:09 AM
PIGGYONAHOG
Its a 49 F1 with a summit V8. the only numbers i can find actually on the block are from inside the truck on the right side of the engine block just above the sump from underneath it looks like 088.the tag that i got the other numbers from looks like it is riveted to the block.
Old Jul 8, 2017 | 01:23 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Not sure what you mean by a "summit" V8? Bought from Summit Racing as a crate motor? It would still have a manufacturer's serial number. A picture of what you have would sure help.
Old Jul 8, 2017 | 12:33 PM
PIGGYONAHOG
yes its a summit crate i believe its a 350 chevy
Old Jul 8, 2017 | 12:35 PM
PIGGYONAHOG
engine numbers
i will get a pic of the motor tomorrow and post it up
Old Jul 8, 2017 | 12:36 PM
PIGGYONAHOG
that is the number on the bottom of the block on right side from inside cab
Old Jul 8, 2017 | 01:02 PM
ALBUQ F-1's Avatar
ALBUQ F-1
It's a casting number, not a serial number
Old Jul 8, 2017 | 01:07 PM
raytasch's Avatar
raytasch
Believe Nothing
If it is a Chevy engine, you should be able to ID from this link.
Small Block Chevy Engine Block casting and code identification
bsteele52
Dec 1, 2008 02:33 PM
gearhead351
Aug 28, 2007 05:20 PM
lavcheech
May 21, 2005 02:56 PM
topo4u2
May 21, 2002 09:18 PM
