Sponsored by: Real Truck
junk yard cluster question
Old Jul 5, 2017 | 09:25 AM
tjbuggie's Avatar
tjbuggie
I am having problems with my fuel guage not working, I have changed the sender and it did not help, so my question is if I get a cluster out of a junk yard can I swap the PSOM out of my cluster into the junk yard cluster so the odometer will be right??
Old Jul 5, 2017 | 11:17 AM
SuperDutyScaler's Avatar
SuperDutyScaler
Yea the pcm holds the mileage reading and the new cluster will show whatbthe pcm has stored
Old Jul 5, 2017 | 11:29 AM
brian42's Avatar
brian42
Veteran: Navy
Make sure you get the right year group for the wiring if you want to make a straight swap. There was a major electrical change between 2001 and 2002 so I don't know how much is a direct swap unless you get a cluster from an '02-'04 truck. Also, the cluster changed as well from all 4 small gages on the left to 2 small gages on each side.
Old Jul 5, 2017 | 07:04 PM
bobv60's Avatar
bobv60
This might be another option
https://circuitboardmedics.com/2002-...luster-repair/
Old Jul 6, 2017 | 09:15 AM
tjbuggie's Avatar
tjbuggie
I talked to those guys, and think I will ship mine off to them later
Old Jul 6, 2017 | 12:11 PM
Mike1's Avatar
Mike1
I assume you already checked but I'll ask anyway. Did you check your wires and grounds?
File Type: pdf
Old Jul 6, 2017 | 03:59 PM
tjbuggie's Avatar
tjbuggie
yes, new sender, even when unpluged the gauge sits at half until the key is turned off.
BluPny
2009 - 2014 F150
Dec 18, 2018 02:30 AM
troverman
Jul 22, 2013 02:30 PM
Nathan Plemons
Jun 14, 2013 01:56 PM
MAULMAUL
Oct 7, 2010 10:26 PM
torchy
2004 - 2008 F150
Dec 11, 2008 11:14 AM
