Failed emissions....AGAIN!
Old Sep 5, 2003 | 02:33 PM
MrDeath8666's Avatar
MrDeath8666
My truck failed emissions today, for the 2nd time. I dont know whats wrong!! Ive replaced my cat converter, egr valve and egr position sensor, o2 sensor, pcv valve, spark plugs, cap and rotor, air filter, and breather filter. I really dont know what else to do with out spending a lot as im short on cash. I really need my truck to pass smog as it is my daily driver. What could be making my hydro carbon and carbon monoxide levels ridiculousy high? Ive also heard if i remove the spout wire or something from the harness connected to the distributor that it will pass emissions, and after just connect it back on. Will that work? I dont know what else to do and i dont have the money for somebody at a shop to look at it right now. I need responses quick and thanks for anybody that does!
Old Sep 5, 2003 | 03:20 PM
Coogles's Avatar
Coogles
Might need to retard timing a little, and at the same time increase ur idle speed to 1000+
and get like a galon of methenol and dump it in a quarter tank of gas. Then after the test fill the tank full of gas.
I dont think the spout connector will help any. Disconnecting that is for setting the timing.
Old Sep 5, 2003 | 03:41 PM
jbalestri's Avatar
jbalestri
First off, do you have any codes in the computer? Even if the CEL isn't on, there might be codes. There has to be something for it to be running that poorly, emissions based.
Old Sep 5, 2003 | 05:55 PM
Coogles's Avatar
Coogles
What exactly did you get for readings? And what size is your motor
Old Sep 5, 2003 | 07:16 PM
MrDeath8666
I got a 91 f150 with a 302. Readings were.....Hydro Carbons --274.5, Limit 143, -Carbon Monoxide -- 3.28%, Limit 1.6% But tomorrow im gonna try to get a waiver, Ohio has this thing if you have spent over $300 trying to make it pass smog theyll do some waiver thing thing for 2 years instead of it passing. So ive put about $410 of crap into so im gonna try to get the waiver and try to fix it after. But still want to find out why its doing so bad.
Old Sep 5, 2003 | 08:46 PM
Coogles's Avatar
Coogles
It could be your timeing. It maybe set too far advanced and then the idle may too low. Thats the opposite of what you want for passing.
If thats not it, maybe you took your test in the cold? Take urself for a drive before you test it, let the engine warm up. Hot engines burn cleaner.
