38R to T4 364.5 SXE Conversion
Old 08-25-2018, 07:53 AM
Lewis50's Avatar
Lewis50
Lewis50 is offline
I'm looking for a good 3.5" down pipe as well, so far all I've found is Diamond Eye's aluminized steel set up. Has anyone used these and are there any other options?
  #242
Old 08-25-2018, 08:05 AM
00t444e's Avatar
00t444e
00t444e is offline
Originally Posted by Silverhks
This brings up the question, does anyone make a quality mandrel bent 3.5" exhaust for these trucks?
Why not just get a 4" downpipe and exhaust? They fit fine on the Super Duty trucks.
  #243
Old 08-25-2018, 08:49 AM
CampSpringsJohn's Avatar
CampSpringsJohn
CampSpringsJohn is offline
The Super Duty have a little more room for a 4" down pipe. On an OBS truck, you'll have to do some major firewall modifications with a hammer and a block of wood to get a 4" pipe in there.
  #244
Old 08-25-2018, 08:53 AM
Silverhks's Avatar
Silverhks
Silverhks is offline
Mostly ,i was thinking, if I go the t4 route I don't want the quick transition from 3" to 4". As I tired that I realized my mental image was wrong. I guess what I would need is a quality 3" DP-back.
it maybe I can find a 3-4 transition pipe in the 3' range, hmm
  #245
Old 08-25-2018, 08:57 AM
00t444e's Avatar
00t444e
00t444e is offline
Yes but I am pretty sure we are all talking about the 99+ trucks here.
  #246
Old 08-25-2018, 09:18 AM
Sous's Avatar
Sous
Sous is offline
Received 4,466 Likes on 2,855 Posts
I am 99% sure that the T4 kit from CSD has a 3.5" downpipe. I bought clamps and adapters to go from the 3.5" downpipe to my MBRP 4" exhaust.
In the 99+ Powerstroke trucks, there is plenty of room for a 3.5" or 4" downpipe and if you are making your own T4 kit, choose whichever you like to mate up to the exhaust of your choice.
  #247
Old 08-25-2018, 06:01 PM
brandon_oma#692's Avatar
brandon_oma#692
brandon_oma#692 is offline
Here you go. Pictures taken today while swapping transmissions. Not the best but a different view than usually posted
  #248
Old 08-25-2018, 10:57 PM
Silverhks's Avatar
Silverhks
Nice pics Brandon.
I guess I should have been more clear on my thought process. I don't feel the need to go bigger than the supplied downpipe for the remainder of the exhaust. If the CSD kit is supplied with a 3.5" DP that should mate perfectly with the stock exhaust. However, my stock exhaust has about reached the end of it's service life. I am loath to let a local muffler shop replace it so I need to find a decent replacement. Before learning about the T4 setup I was planning on the MBRP 4", I might still do this.
BTW, thanks to all of you guys who are leading the way on this.
  #249
Old 08-26-2018, 06:16 AM
SRBF150's Avatar
SRBF150
SRBF150 is offline
I would just go with the 4" kit. They're available, reasonably priced and work great.
  #250
Old 08-26-2018, 06:54 AM
Lewis50's Avatar
Lewis50
Lewis50 is offline
I need to fess up to my cheap nature regarding the 3.5" down pipe for my modified stock turbo. My exhaust is still in good shape and with the 4" Aeroturbine muffler flows a good bit better. I'll eventually swap to a 4" system but am looking for a stopgap solution to the stock downpipe's less than adequate diameter/flow, thus my quest for a 3.5" replacement. Any ideas or experience with existing products?
  #251
Old 08-26-2018, 11:41 AM
brandon_oma#692
Where are you from.
Edit. I have a 4 inch down pipe I've been trying to give away but I am too lazy to ship it. It is in the classified section and the free parts thread.
  #252
Old 08-26-2018, 01:17 PM
Lewis50's Avatar
Lewis50
Lewis50 is offline
Brandon,
I'm in northern Georgia, a good hike from your neck of the woods. I appreciate the offer though.
  #253
Old 09-01-2018, 09:11 PM
565edge's Avatar
565edge
565edge is offline
Started putting my t4 CSD kit on today. I have the t4 mount in and the down pipe sbf up-pipes in. What does everyone think about the oil line angle? Do you have return and feed going straight up and down or at angle? Or do I just get the turbo in and what angle works then I'm good? The Brad let me know to not go over 20 Degree of angle with center section.
  #254
Old 09-01-2018, 09:12 PM
565edge's Avatar
565edge
565edge is offline
  #255
Old 09-01-2018, 09:13 PM
brandon_oma#692
I attached the return line then rotated the center section so it was as far down as possible and backed it off just a tiny bit.
Quick Reply: 38R to T4 364.5 SXE Conversion
