1995 F-150 overheating? NEED HELP FAST
Old Nov 19, 2001 | 02:30 PM
95xltmud's Avatar
95xltmud
[updated:LAST EDITED ON 19-Nov-01 AT 03:45 PM (EST)]My 95 f-150 4x4 5.0L seems to be overheating today. When i am at a stop light and just idling, the temperature goes all the way to H, but there is only cold air blowing from the vents, when I rev the engine in neutral or drive it up to speed, the air will get really hot and the temperature will go back to normal. What is the problem? Thermostat? water pump? Need feedback ASAP thanks.
-john
Old Nov 19, 2001 | 03:00 PM
Pastmaster's Avatar
Pastmaster
Sounds like the Thermostat for sure stuck closed. Squeeze the upper hose and the lower hose and see if they'res water in both. Most likely the upper hose will have water but not the lower.
Also make sure you have fluid in the radiator.
Is it boiling out the bottle?
'93 F-150 loaded and modified!
Several other project vehicles
Old Nov 19, 2001 | 03:23 PM
s_laviolette's Avatar
s_laviolette
