1978 - 1996 Big Bronco
Resurrection suggestions....
Old 06-29-2017, 09:16 AM
varminthunter243's Avatar
varminthunter243
varminthunter243 is offline
So after sitting for over 5 years, I will begin bringing my bronco back to life soon. When it was parked it was simply because the battery was toast. A couple weeks after that, I tried to jump her but when I turned the key on, fuel started leaking from the inlet line for the electric fuel pump. So besides those 2 items, and draining the old fuel, what else would you guys recommend I do before cranking her back up? I figure hoses and belts should probably be replaced? As well as pre oiling the cylinders? And I could use your input on the best way to do that as well....
Old 07-07-2017, 06:58 PM
fe390pc's Avatar
fe390pc
fe390pc is offline
What year truck do you have? Sounds like it is injected so you have that system to inspect. I would say the biggest thing is to go over the vehicle front to back checking all the systems needed to start the vehicle.
1) Exhaust
2) Fuel lines
3) Fuel Tank
4) Ignition, Plugs, wires, cap and rotor
5) Fluids (Gas, Oil and water/radiator)
6) Belts, Hoses and wiring
Once all that has been at least looked at and any leaks fixing and fluids topped off or replaced. I would pull the fuse for the fuel pump and put a little marvel mystery oil in each cylinder then bump the key to verify the engine turns.
Good luck and lets see so picks.
Old 07-07-2017, 11:01 PM
varminthunter243
1) Exhaust
2) Fuel lines
3) Fuel Tank
it used to be in my signature but I guess my signature left haha it's a 78 bronco ranger xlt. 400 C6, 4.11's. Retrofitted with an electric fuel pump. Wearing a stock manifold and carb but as soon as she's running again I plan on an edelbrock perforer dual plane and Holley 600. I will definitely need to clean the tank. And new brick and plugs. Would it be better to try and turn the motor by hand first? Or will pulling the plugs be sufficient enough for reducing the load? And should i pull the coil wire or something to keep it from arking?
Old 07-08-2017, 07:45 PM
fe390pc's Avatar
fe390pc
fe390pc is offline
If you can turn the motor by hand that is good to do. If if can get it to turn more than one full revolution even better. That way you know there is no rust in the cylinders. Post some pics of your ride when you get a chance, also good luck.
Old 07-08-2017, 08:18 PM
varminthunter243
Will do! And I greatly appreciate the advice
Old 07-09-2017, 06:59 PM
fe390pc's Avatar
fe390pc
fe390pc is offline
That's why we are on here.
chirkware
26
04-09-2019 01:08 AM
peakster
01-25-2016 10:47 PM
one1ll1282
11-08-2012 08:57 PM
fancyvern
04-18-2012 05:37 AM
Gear Up
03-16-2006 09:33 PM
Quick Reply: Resurrection suggestions....
