Dual Wheel Conversion?!
Old Sep 5, 2003 | 08:11 AM
BEAST428's Avatar
BEAST428
i have a 1974 f250 that i put a dana 70 drw axle under the rear. i want to put duals on it but have not come up with a combination of tires and wheels that will give me the same or close height as the 38.5 gumbo mudders that i have on front. any suggestions
Upper Case Edited Out by FTE
Old Sep 5, 2003 | 08:13 AM
c_rossman's Avatar
c_rossman
Duals will actually make traction in mud worse, the outside wheel likes to get hung up.
Old Sep 5, 2003 | 08:21 AM
BEAST428's Avatar
BEAST428
you would have to see this truck? to understand.
it is an ex cab with the back half of a 78 bronco on it.
a built 428 police interceptor engine, 6" frame lift,
lots more
very odd looking and i want to make it odder
thats why the dual idea.
thanks for the reply.
Old Sep 5, 2003 | 08:43 AM
c_rossman's Avatar
c_rossman
Oh I See, The only tire I could think of would be a commersial type tire for like a semi or dump truck that would be that high and skinny enough to be side by side.
Old Sep 5, 2003 | 09:05 AM
F-750pickup's Avatar
F-750pickup
Yes, commercial truck wheels and tires would give you the height that you are looking for. you can run 22.5" wheels, but they come in 10 lug. Chromewheel.com sells adaptors from 8 to 10 lug just for this type of conversion. steel wheels are easy to come by, or you can go with alcoas$$. Tire selection is pretty good also.
Old Sep 5, 2003 | 02:59 PM
Colossus's Avatar
Colossus
What do you mean dual's get worse traction? In my experience, the amount of weight on the rear axle determines how much traction you have.
Old Sep 5, 2003 | 06:14 PM
c_rossman's Avatar
c_rossman
It depends, if its deep mud or snow, the outside wheel will cause more harm than good, ICE, it may be a different story.
Old Sep 5, 2003 | 06:38 PM
Colossus's Avatar
Colossus
So the mud would have to be pretty thick to get the outer tire stuck. hmm...That shouldn't be a problem for me. I drive mostly through soft ground, wet - but not muddy, and some snow. Does it also have to do with the fact that the weight of the rear end is spread out on 4 tires and not 2?
dljerome
Oct 1, 2008 12:20 PM
F700 Pickup_man
Apr 7, 2008 11:09 PM
pbssouthland
Aftermarket Products
Jul 10, 2006 10:36 PM
ewnelson
Mar 17, 2005 12:53 PM
shoe
Jul 11, 2001 07:30 AM
