MPG & PSI Question
Old Sep 5, 2003 | 07:54 AM
Ruff93's Avatar
Ruff93
MPG & PSI Question
Recently purchased an 01 Excursion with 32K miles from a friend whom works at a Ford dealer - was the owners son's car so the history of the vehicle is known and is good. Didn't buy the vehicle for the mpg's, bought it for what it is - a simply awesome do-it-all truck. Wife loves it! I tow a 27' travel trailer easily. My MPG's are around 10-11 around town, 8 when towing, and 13 to maybe 14 on the highway. I was wondering if any other owners have added simple aftermarket products to the V-10 motor that successfully increases mpg's. I am waiting for my K&N filter to arrive, and threw one of those "Fuel Master" magnets on the fuel line. The fuel master hasn't helped at all thus far. I was considering trying out one of those Tornado gadgets but have read nothing but negative reviews about it so I opted not to waste my money. Any other mods available to increase mpg's? How about tire pressure? I believe I am running 38 all around, whatever the door panel recommended to run. Seems low considering the max psi listed on the tire. What is a good pressure to run and will psi increase mpg's?
Thanx for any info.
Old Sep 5, 2003 | 08:31 AM
MN_Wild's Avatar
MN_Wild
MPG & PSI Question
Magnets and tornados = snake oil. My X reccomends 55 in the tires. I think your fuel economy is pretty good for the v10. Good luck
Old Sep 5, 2003 | 08:57 AM
jdadamsjr's Avatar
jdadamsjr
MPG & PSI Question
I have to agree with the snake oil :-)
And you're right, air pressure will affect mpg....
but I've always considered my kidney's well being over the fuel mileage
I may up the air if I'm going on a long interstate trip where I know the roads will be better... but the secondary roads are too brutal for my 'fragile body' to keep the 55-60 lbs in them -
I usually run it more around 40-45 on our '03 4x4 6.0L...
good luck with it !!! And you're right - it IS the best travelling vehicle around...
on edit - do a search for v-10 mpg - I think I recall a thread just about this topic.... u might consider a programmer - they DO increase the mpg by increasing the effeciency of your motor...
Old Sep 5, 2003 | 07:29 PM
Jakebrake's Avatar
Jakebrake
< Samantha...my Co-Pilot
MPG & PSI Question
I run 50 psi front and rear in my Excursion, and it seems to be a good compromise. Gas milage is 14 to 17 on the highway, tire wear is good, and ride is good. I have the Firestone OEM tires and Edelbrock IAS shocks. The shocks are much better than the factory shocks, and the reduced pressure in the tires allows for a good ride.
P.S. Tornados and other such devices are useless in my opinion, and thats my opinion!
Toolman30
May 12, 2014 05:43 AM
aeroskies
2009 - 2014 F150
20
Dec 14, 2013 11:06 AM
onug
Modular V10 (6.8l)
23
Jun 10, 2012 10:10 PM
Fredvon4
Modular V10 (6.8l)
26
Nov 9, 2005 05:18 PM
JoeBoost
Mar 8, 2003 11:40 AM
