Sponsored by: Auxito
Engine identification and oil starvation
Old Jun 26, 2017 | 06:04 PM
pounder90's Avatar
pounder90
Posting this in hopes it helps someone with similar problems. I always thought I had a Romeo motor due to the VIN. I was wrong, it's a Windsor. I should have asked here first. Anyway, motor starting ticking. I thought it was an exhaust leak. No leaks, manifolds look perfect, truck has never been out of Florida. Used a mechanics stethoscope, noise pointed to timing chains. Got a quote from local Indy shop for $1500, decided to do it myself, with help from a buddy. Ordered the timing chain kit from internet. The tensioner arms and guides did not match. For one, I ordered the Romeo kit, second my truck is titled as 01, but manufactured in August so parts match 02. Ford dealer quoted $525 for the guides/tensioner arms. Got Cloyes from O'Reilley's for $95. Plastic guide on passenger side was completely destroyed. Cam on passenger side was dry and showed signs of heat. There was damage at cam clamps,
smoothed all surfaces and put back together with assembly lube. Took apart the oil restrictor at the back of the head. It had what looked like filter material blocking the small port in the restrictor. I have only used Motorcraft filters, but I'm not the original owner. Verified good oil flow before putting valve covers back on. The job took a day and a half. Replaced both chains, tensioners, guides, tensioner arms, valve cover gaskets, water pump, serpentine belt. Running like new now, quiet and smooth, all power restored.
Old Jun 27, 2017 | 01:38 PM
pdqford's Avatar
pdqford
Nice report.
Thank you.
Old Nov 28, 2023 | 09:03 AM
2005 f150 4.6's Avatar
2005 f150 4.6
4wd Low
i think I have same problem on f150 4.6 Windsor 2005, my new lifters won’t pump up and I’m getting ticking thru out passenger valve cover, I suppose it’s best for me to check/change tensioner. Also, do you have to take cam shaft out to clean check restrictor? Or just remove a cap? Thanks
blueovalandy
2004 - 2008 F150
Jun 16, 2025 05:37 PM
Megalodon4g63
1997 - 2003 F150
Jun 10, 2019 02:18 PM
american jcm
2004 - 2008 F150
Mar 19, 2019 05:05 PM
SmokeBlower
Mar 5, 2010 10:38 AM
burninfordrubber
1997 - 2003 F150
Jan 26, 2007 08:18 PM
