Sponsored by: Real Truck
Need help with 04 6.0
Old Jun 26, 2017 | 05:26 AM
calvinbabb's Avatar
calvinbabb
I have a 2004 6.0 with 200k miles. Was running great till last weekend and the it was like have the engine shut down 1/2 the injectors. It's not throwing any codes. I change fuel filters just in case and drained the water separator and had minimal water. The ICM is right in the middle of Ford spec. Pulling me hair out over this. If I lost 1/2 the injectors would it through a code? Never heard of anyone loosing that many at once. It is stock other than egr delete. No apparent head issued. Just not injecting fuel the way it should. Got it home, had plenty of boost. Hopefully this is something someone here has felt with and point me the right direction.
Old Jun 26, 2017 | 06:46 AM
xcrsp440's Avatar
xcrsp440
What did you use to look for codes?
Old Jun 26, 2017 | 07:18 AM
calvinbabb's Avatar
calvinbabb
scan gauge II. wouldn't the check engine light come on if there was codes the scan gauge couldn't read.
Old Jun 26, 2017 | 09:38 AM
Mike189677's Avatar
Mike189677
No you can have codes with out the check engine light being on including injector contribution balance codes. The scangauge is a crappy code reader stop by an auto parts store and use there code reader and see what you come up with or stop by a shop and have them scan it some places will do it for free. I would seriously doubt you lost a bunch of injectors at once. Hopefully a mod will stop by and move this to the 6.0 section for you be ready to provide those guys with some numbers from that scangauge.
Old Jun 26, 2017 | 11:19 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
While you're figuring out how to get it scanned... check the plugs on the bottom of the FICM and make sure they're clicked all the way in.
If one of the clips was broken and the connector backed out you can literally lose a whole bank at once, but this is a long shot because the truck would run horribly if at all, and I'd think the CEL would get set for something that drastic.
You should also enter the ICP_V code into the ScanGuage, to see what the sensor itself is reading. It's been while since I used my old SGII but IIRC the ICP pressure code is desired and not actual. So you're seeing what the PCM wants but not what the sensor is reading.
Originally Posted by ICP_V Code
ICP Voltage (Volts)
TXD: 07E02216AD
RXF: 0462451606AD
RXD: 3010
MTH: 004827100000
NAM: ICV
KO=0.2 LI=1.0 HI=1.8 OR=.15-4.7 Volts
Old Jun 26, 2017 | 11:38 AM
xcrsp440's Avatar
xcrsp440
Our 6.0 was showing cylinder 2 misfires codes, but no check engine light. Then changed all injectors on drivers side, didn't plug ficm properly. Broken tabs. And on restarting got cylinder contribution codes on cylinder 5. Took two more attempts to get ficm plugs properly seated. All again with no check engine light
We use an iPad app called Forscan, cheap to buy, and also need a obd wifi adapter. Get them both for under $40.00
Old Jun 26, 2017 | 12:12 PM
calvinbabb's Avatar
calvinbabb
It acts as if i lost the left side of the engine and runs very rough so it may be that. I won't get time till this weekend to check the plug though.
Old Jun 26, 2017 | 12:41 PM
xcrsp440's Avatar
xcrsp440
You are just guessing until you actually get a scan and codes.
Old Jun 26, 2017 | 12:44 PM
calvinbabb's Avatar
calvinbabb
Yea, I know. Looking up a obd scanner for usb and windows now and waiting on FORSCAN to approve me for the program.
Old Jun 26, 2017 | 01:57 PM
calvinbabb's Avatar
calvinbabb
Thx. just ordered a OBD to usb to plug into my laptop and waiting for Forscan to approve me so i can download it and order the extended lisc. The scanner cost me 40 due to getting a 15' extention for it and i bought one that had a 3 year warranty.
Old Jun 26, 2017 | 02:18 PM
xcrsp440's Avatar
xcrsp440
You purchased more than I did. Forscanlite app for iPad was $5.00. Obd wifi adapter was $20.00. That was all I needed to check codes and monitor vitals.
You will probably be able to do much more.
Old Jul 2, 2017 | 07:45 AM
calvinbabb's Avatar
calvinbabb
well, got it scanned and turns out the wiring harness to the injectors went bad. 4 out of 8 injectors not firing off. ordered new harnes and while i was at it upgrading the FICM to a 58 volt. also fixing a small oil leak i've had where the filter tower bolts to the oil cooled. been leaking since i replaced the oil cooler 2 years ago. figured while i was tearing into stuff, might as well fix it.
Old Jul 2, 2017 | 10:46 AM
jetjockey99's Avatar
jetjockey99
DON'T upgrade to a 58 volt FICM! Go to FICMrepair.com and you can read why, they are one of if not the best places for FICM repair/updating and all other Ford parts, any questions talk to ED.
Old Jul 2, 2017 | 01:49 PM
calvinbabb's Avatar
calvinbabb
Thanks. .
Old Jul 2, 2017 | 02:36 PM
texastech_diesel
Token Redneck
Unless it's made by Bullet Proof Diesel, the 58V FICM is 100% a gimmick IMO. The BPD one apparently uses a custom designed billet heat sink and a 5th (and 6th?) power supply to up the voltage, that's a real re-design. Some other 58V units just cram more into the original setup, increase the heat factor, and burn up the same way the old one did.
The injectors were spec'd to run at 48V. If you for some reason feel the need for 58V to overcome stiction or advance timing, or whatever the root point of the 58V upgrade it, then the FICM isn't the place to be putting the band-aid for that problem.
Were there soft codes set for the whole bank? How'd the narrow down to they harness, and not a connector?
