295/70/18 or 35X12.550 on 18X9 wheel
Old 06-24-2017, 07:54 PM
2civicrr's Avatar
2civicrr
2civicrr is offline
Looking for some input/opinions on which size tires to get.
I have a leveled 2015 6.7 F350 crewcab shortbed 4X4. I've decided on a 18X9 wheel with 5" backspacing.
I believe both size tires will clear with no rubbing issues. Should I go with the 295/70/18 or 35"X12.5" size? Any pics you have of your truck would be appreciated too.
Thanks
Old 06-26-2017, 12:57 AM
RainDesert's Avatar
RainDesert
RainDesert is offline
Yeah they both will fit no problem. I really like the 295's due to the higher weight rating and being slightly narrower. It is my favorite size offered today in that "35" range.
Old 06-27-2017, 09:51 PM
2civicrr's Avatar
2civicrr
2civicrr is offline
Thanks for the reply.
Although I don't currently tow heavy, I'm thinking the same about the weight rating. Using Toyo AT2 for comparison, I'm only giving up 3/4" of width vs the 35X12.5 Too bad the R/T doesn't come in 295/70/18.
Old 06-28-2017, 12:07 AM
RainDesert's Avatar
RainDesert
You have the diesel, if you want the RT's go with the 285/75/18's, same big 4080lb capacity but a little taller. That diesel handles the taller tires much better than the 6.2.
mattie dog
2015 - 2020 F150
03-13-2018 09:16 AM
Windmill65
Fifth Wheel & Gooseneck RV Towing
08-07-2017 03:38 PM
dcullen
06-06-2012 10:34 PM
Dually TAS
02-25-2009 06:44 PM
tgowers
1997 - 2003 F150
05-11-2007 11:11 PM
Quick Reply: 295/70/18 or 35X12.550 on 18X9 wheel
