2017 Super Duty Sync 3 AIPM Potential Issues
Old Jun 24, 2017 | 01:16 PM
wharrell's Avatar
wharrell
Ever since my 2017 Super Duty 12/19/2017 was delivered in February, the USB Music option has not worked
Not on an IPhone 6, IPhone 6 Plus. IPad Air, Ipad Mini 4 and not an IPod Touch all with latest Apple Software
The hope was Sync 3 Version 2.2 would fix the issue
Yesterday my servicing dealer installed Version 2.2 via IDS install
The 2.2 version did not fix the issue and now when the system hangs with An attempt to use USB music, the entire system has other issues with Sync voice commands not working and phone calls can not be made nor received
The dealer is at a loss to get this fixed
I have now asked them to ask Ford to replace the AIPM module
Am I on the right track?
All of these devices worked perfectly with no issues on the previous 2015 Super Duty Sync 2 system but never have worked with Sync 3
https://i.imgur.com/g8HTLjs.jpg
Old Jun 24, 2017 | 07:01 PM
maabx's Avatar
maabx
If it is Apple Carplay you are trying to get working, I was under the impression that for vehicles delivered with Sync 3 2.0, the fix for Carplay required the 2.2 upgrade and a hardware upgrade. Maybe something having to do with the USB hardware interface(??).
My USB audio works fine from a jump drive. It takes a while to respond the first time it reads the drive.
Old Jun 24, 2017 | 07:09 PM
mrpickles's Avatar
mrpickles
My truck is job 1 w Sync 3 2.0 and Apple CarPlay works just fine and USB audio works too as of the first day I drove it.
My understanding i the 2.2 upgrade is only for 2016 and below vehicles and adds nothing to the 2017 model and in fact may do harm.
Old Jun 24, 2017 | 07:10 PM
wharrell's Avatar
wharrell
It is not Car Play
It is using Apple Devices for streaming cloud music come from any number of sources and preserving the factory navigation and weather etc
Thanks for yur reply
I think the AIPM is faulty
Old Jun 24, 2017 | 07:56 PM
maabx's Avatar
maabx
Thanks for the clarification on the 2016 vs 2017.
"now when the system hangs with An attempt to use USB music, the entire system has other issues with Sync voice commands not working and phone calls can not be made nor received"
I observed the same behavior when plugging in a jump drive with 4,600 music files. It took many minutes to complete the indexing, and Sync 3 was all tied up in knots and would not respond to commands until the indexing was completed.
Old Jun 24, 2017 | 08:12 PM
wharrell's Avatar
wharrell
I have wondered if Sync 3 is resource constricted
Still all of these devices worked flawlessly with the same size Apple Cloud Music library on Sync 2 on my previous 2015. Also many times I am just streaming content from my web server or using Vox or Tidal
I am highly disappointed in Sync 3 as it should not be so unreliable
Old Jun 26, 2017 | 05:04 PM
savage250's Avatar
savage250
I have a job 2 truck and one day my USB system just died entirely. It had been working for a few weeks prior. I did a master reset and it came back and hasn't failed again since. When I was using ForScan for a few other things I noticed an error with a module (can't recall which one) that said it lost communication with the APIM. I'm guessing my issue will resurface eventually and I'll take it to the dealer. I've also had the unit freeze up when I press the Sync voice button on the steering wheel but it was fine after a restart.
One other day I lost both Bluetooth and GPS... both returned after restarting the truck.
Hopefully these issues do not get worse.
NDE
6.7L Power Stroke Diesel
Feb 1, 2018 12:25 PM
Ford Trucks
Official Ford Forum : Ask an Engineer
Aug 27, 2016 09:53 PM
DerekShiekhi
Aug 17, 2016 03:04 PM
ZEALOUS_DRAGON
Dec 22, 2011 05:30 AM
Bohemian
Jun 11, 2009 10:36 AM
