Swapping 92 460 into 87
Old Jun 22, 2017 | 06:01 PM
Pappawheely's Avatar
Pappawheely
I bought an 87 F250 that was missing the 460 motor. I have a running 460 from a 92 that I can swap in. The manual trans from the 92 is going into my 97 that is 2wd and an auto. I know that sounds crazy but there is a reason for all of it. My question is about the engine wiring and computers. Is the engine wiring harness on the 92 all one harness or is it looped into other circuits in the truck? Do I need to keep the computer with the engine and swap that into the 87 or keep it with the transmission going into the 97? The 87 had a 460 engine so will the 87's harness run the 92 motor? Thanks in advance.
Old Jun 22, 2017 | 06:15 PM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
Off the top of my head I thought the 87 was carbureted.
Old Jun 22, 2017 | 06:20 PM
Pappawheely
This truck had a 460 FI, and C6
Old Jun 22, 2017 | 10:03 PM
HardScrabble
So it looks like both were built for 87.
I have heard it said that you generally don't use the wiring from a donor vehicle.
Is the 1997 truck an OBDII system?
Old Jun 22, 2017 | 10:06 PM
Pappawheely
The 97 is OBDI because it's a cab & chassis.
Old Jun 24, 2017 | 11:41 AM
Pappawheely
Bump.
Old Jun 24, 2017 | 12:06 PM
bbf385's Avatar
bbf385
If you have all the wiring from the '87 (including the engine overlay for the injectors) then the 92 will plug right in. None of the wiring from the '92 will work with the older truck.
The only difference is the fuel rail. '92 should connect at the rear of the engine by number 8. The '87 would have connected at the front by number 5.
Computer will run the engine but you will have to wire it so it think the clutch pedal is pressed.
Not sure on the black/gray TFI ignition differences and what year it started. Truck will run regardless.
Old Jun 24, 2017 | 12:08 PM
bbf385's Avatar
bbf385
unless you have the original computer for the 87 then none of the clutch or tfi stuff matters.
Old Jun 24, 2017 | 02:26 PM
Pappawheely
Thanks! I have the wiring from the 87 but it is mouse damaged.
Old Jun 25, 2017 | 04:54 AM
Diesel_Brad's Avatar
Diesel_Brad
87s were still carb.
EFI did not come out till 88
87 had a ecm of some sorts for the 460
87-91 had round firewall plugs
92-97 had square firewall plugs
Old Jun 25, 2017 | 12:44 PM
Pappawheely
Thanks Brad. The build date is 09-87. It has an ecm and round firewall plug. I bought it with no engine but it came with a pile of parts the owner said came off the truck which included an efi intake and throttle body. The motor I am swapping in is efi (92). Is the engine harness a closed system that only runs the efi and sensors or is it part of the entire truck harness? I'm having a problem finding a decent schematic.
Old Jun 25, 2017 | 02:51 PM
HardScrabble
Does it have the emissions sticker under the hood?
Numbers on the computer?
For wiring details you might luck out on an EVTM on eBay.
Old Jun 28, 2017 | 07:13 PM
Diesel_Brad
That most likely means it is a 88 truck. What is the 10th digit of the vin. THAT tells you what year it is.
Old Jun 28, 2017 | 08:22 PM
Pappawheely
Yup, it's an 88. Thanks.
Old Jun 29, 2017 | 05:16 PM
Diesel_Brad
And there an other mystery explained
Psychowolff1
Jan 6, 2018 08:22 AM
78d100
Engine Swaps
Jun 24, 2007 10:07 PM
1987blueovalcrazy
Aug 28, 2003 08:05 PM
jim henderson
May 1, 2001 11:30 PM
